After TWIN Switch over IPtouch phones do reset
ismohamm
Post by ismohamm »
Hi Experts,
I have weird problem with OXE, i have twin servers and after executing "bascul" phones star reboot.
with reset cause 13. and after all network return to stability again.
any advise
Re: After TWIN Switch over IPtouch phones do reset
that's because your IP Touch does not have the correct CPU Information.
Check your labpbx file. If you are not using wireless nor emcryption, you can actually delete the file. It's created on the fly when an ip phone request it no matter what.
