Side Project:CDR Real-Time on Ethernet
alex
Post by alex »
Hi there
Proud to present Yet another CDR collector - this time in pure Powershell! No Java, no python, no libraries, no additional modules needed. Just one Powershell script (created only for educational purposes).
So if you want to test it - get it from GitHub https://github.com/Jeepers-Gitters/OXE_EAcc.git or just download script itself and .ini file.
Re: Side Project:CDR Real-Time on Ethernet
What does it do exactly ?
alex
Post by alex »
Its just collects real-time tickets (CDR,VoIP,MAO) on Ethernet, writes them in files for further processing. Also it shows short CDR string:
Full description is on Github page.
excellent!
alex
Post by alex »
frank wrote: 06 Jun 2024 11:20excellent!
Thanks, Frank
Almost ready to roll out version 1.0.
In a meantime just ported my old-time QB project https://github.com/Jeepers-Gitters/ALU_OXE_OPS
alex
Post by alex »
Update: version 0.9 published
Added:
  • Redundancy/Spatial Redundancy support. When TCP connection is lost script switches to Standby CPU address and back
  • Ctrl-C press handled by script for clear exit
  • Some minor improvements and corrections
Return to “CDR Real time on Ethernet”
