Can I use 510W power for a 6850E(non-poe switch)
limeplus2555
Post by limeplus2555 »
There's a 6850E-24 switch
There is no power.
Looking at the data sheet, it says 126W power is applicable
Can I install 510W (POE switch) power?
We have 510W power.
Re: Can I use 510W power for a 6850E(non-poe switch)
Try it. It should work
