Hi all,
We have an OXE CS/PCS system, where the CS broke and we needed to change it, today it is working rescued from the PCS.
We do not have backup of the database, so we were thinking of changing the licenses to the CPUID of the PCS board in order to avoid delays in loading the software, database, etc.
Is it possible to make this change without losing the current configuration?
Besides changing the corresponding IPs, can you think of anything else to take into account?
Thanks in advance.
M
Change PCS board to main CS?
Re: Change PCS board to main CS?
Besides the licenses files, i Guess that you need ONLY to make PCS netadmin egual to the CS netadmin
You need to use netadmin on PCS and Change the IP addreass, name in order to the PCs has the faulty CS IP addreass and name. If possíble, the easy way is to restore a chorus backup from the faulty CS on PCS
