Layer 2 Multicast Issue OS6360-OS6560
successor169
Post by successor169 »
We're encountering an issue with Layer 2 Multicast functionality on our network, impacting IPTV delivery across building.
Here's a breakdown of the problem:
IPTV devices are acquiring IP addresses from the DHCP server but are unable to connect to the main server for content.
The main server is reachable (pingable) from both the core and access switches, indicating the issue is specific to multicast traffic
OS6360/OS6650 multicast config
ip multicast admin-state enable
ip multicast querying enable
ip multicast zapping enable
ip multicast querier-forwarding enable
ip multicast vlan 1140 admin-state enable
ip multicast vlan 1140 zapping enable
successor169
Re: Layer 2 Multicast Issue OS6360-OS6560
Need assistance in order to resolve this issue. thanks
I understand all your IPTV-devices in the same vlan. So no routing is necessary. Correct?
And all your switches have an ip interface in this vlan. So one of them is the querier (check with "show ip multicast querier" at all switches).
Try to find the issue step by step:
1. direct connection (or via a stupid switch) your main server and iptv-client. Does it work?
2. than over one switch with the given config. Does it work?
There are also a lot of troubleshooting commands to find the reason. All of them starts with "show ip multicast...."
BR Silvio
successor169
hi Silvio
its connected through server from switch. even iptv client in the same switch not working. both are pingable from switch but the iptv client not able to connect to the main server. when the server from switch disconnect from network its start working.
yes, when disconnect from network its working
i am sharing snapshot for Server form , core switch and one of the access switch. please check
IPTV server are connected to server-form switch.
Sorry - I haven't fully understand.
Does it work if Server and client are connected at a stupid switch (or omniswitch with multicast disabled)?
If this is working than use the omniswitch with enabled multicast. Your output about the querier shows that in every vlan there is at least one querier (very important). CPU means this switch offers the querier - port x/x means the querier is connected there.
Please use the other commands:
show ip multicast source / group /forward / bridge /bridge-forward
What do you mean with "yes, when disconnect from network its working"?
successor169
yes, its working
i disable multicast on all other vlans and keep it enable for management and iptv vlan only.
now its working but i will keep monitor for one day and will update you if there is any issue.
show ip multicast group
Total 20 Groups
* Denotes IPMVLAN/RVLAN
Group Address Source Address Vlan/Service Interface Mode Static Count Life
230.40.50.10 0.0.0.0 vlan 1140 1/1/1 exclude no 148 172
230.40.50.31 0.0.0.0 vlan 1140 1/1/1 exclude no 19 153
230.40.50.40 0.0.0.0 vlan 1140 1/1/1 exclude no 7 148
239.255.255.250 0.0.0.0 vlan 1140 1/1/1 exclude no 225 155
230.40.50.10 0.0.0.0 vlan 1140 1/1/2 exclude no 137 221
239.255.255.250 0.0.0.0 vlan 1140 1/1/2 exclude no 91 156
230.40.50.10 0.0.0.0 vlan 1140 1/1/3 exclude no 26 148
239.255.255.250 0.0.0.0 vlan 1140 1/1/3 exclude no 411 156
230.40.50.10 0.0.0.0 vlan 1140 1/1/4 exclude no 56 148
230.40.50.20 0.0.0.0 vlan 1140 1/1/4 exclude no 22 149
230.40.50.21 0.0.0.0 vlan 1140 1/1/4 exclude no 20 149
230.40.50.42 0.0.0.0 vlan 1140 1/1/4 exclude no 20 150
239.255.255.250 0.0.0.0 vlan 1140 1/1/4 exclude no 518 156
230.40.50.12 0.0.0.0 vlan 1140 1/1/5 exclude no 28 153
239.255.255.250 0.0.0.0 vlan 1140 1/1/5 exclude no 444 156
230.40.50.22 0.0.0.0 vlan 1140 1/1/6 exclude no 4 149
230.40.50.41 0.0.0.0 vlan 1140 1/1/6 exclude no 30 152
230.40.50.70 0.0.0.0 vlan 1140 1/1/6 exclude no 70 150
238.0.0.2 0.0.0.0 vlan 1140 1/1/6 exclude no 28 151
239.255.255.250 0.0.0.0 vlan 1140 1/1/6 exclude no 277 254
:-> show ip multicast group bri bri
bridge bridge-forward
:-> show ip multicast bridge
Total 20 Bridge Entries
* Denotes IPMVLAN
Vlan/Service Type Group Address Host Address Action UpTime
vlan 1140 asm 224.2.127.254 filtering 00h:33m:54s
vlan 1140 asm 230.40.50.10 forwarding 01d:00h:24m
vlan 1140 asm 230.40.50.11 filtering 00h:33m:56s
vlan 1140 asm 230.40.50.12 forwarding 00h:33m:56s
vlan 1140 asm 230.40.50.20 forwarding 01d:00h:24m
vlan 1140 asm 230.40.50.21 forwarding 01d:00h:24m
vlan 1140 asm 230.40.50.22 forwarding 00h:33m:56s
vlan 1140 asm 230.40.50.30 filtering 00h:33m:56s
vlan 1140 asm 230.40.50.31 forwarding 01d:00h:24m
vlan 1140 asm 230.40.50.32 filtering 00h:33m:56s
vlan 1140 asm 230.40.50.40 forwarding 01d:00h:24m
vlan 1140 asm 230.40.50.41 forwarding 00h:36m:15s
vlan 1140 asm 230.40.50.42 forwarding 01d:00h:24m
vlan 1140 asm 230.40.50.43 filtering 00h:33m:56s
vlan 1140 asm 230.40.50.50 filtering 00h:33m:56s
vlan 1140 asm 230.40.50.51 filtering 00h:33m:56s
vlan 1140 asm 230.40.50.52 filtering 00h:33m:56s
vlan 1140 asm 230.40.50.60 filtering 00h:33m:56s
vlan 1140 asm 230.40.50.61 filtering 00h:33m:56s
vlan 1140 asm 230.40.50.70 forwarding 00h:36m:15s
:-> show ip multicast bridge-forward
Total 13 Bridge Forwarding Entries
* Denotes IPMVLAN
Vlan/Service Type Group Address Host Address Next Interface UpTime
vlan 1140 asm 230.40.50.10 1/1/1 01d:00h:24m
vlan 1140 asm 230.40.50.10 1/1/2 01d:00h:24m
vlan 1140 asm 230.40.50.10 1/1/3 01d:00h:24m
vlan 1140 asm 230.40.50.10 1/1/4 01d:00h:24m
vlan 1140 asm 230.40.50.12 1/1/5 00h:33m:59s
vlan 1140 asm 230.40.50.20 1/1/4 01d:00h:24m
vlan 1140 asm 230.40.50.21 1/1/4 01d:00h:24m
vlan 1140 asm 230.40.50.22 1/1/6 00h:33m:59s
vlan 1140 asm 230.40.50.31 1/1/1 01d:00h:24m
vlan 1140 asm 230.40.50.40 1/1/1 01d:00h:24m
vlan 1140 asm 230.40.50.41 1/1/6 00h:36m:18s
vlan 1140 asm 230.40.50.42 1/1/4 01d:00h:24m
vlan 1140 asm 230.40.50.70 1/1/6 00h:36m:18s
:-> show ip multicast bridge-forward source
Total 0 Sources
Source Ingress
Group Address Host Address Tunnel Address Vlan/Service
BUILDING-C-CORE-SW:-> show ip multicast source forward
Total 0 Forwards
* Denotes IPMVLAN
Ingress Egress
Group Address Host Address Tunnel Address Vlan/Service Vlan/Service Interface
please assist why i am not geting any output for ip multicast source/forward. thanks
normaly this shouldn't an association. If multicast is global activated than it is at all vlans.
If the stream is standing for more than 250 sec. all is okay :-)
This are your iptv-streams: 230.40.50.x ?
With show ip mc group you see the MC-clients (sending out the igmp messages).
With the forward-commands you see the forwarded mc-stream from server to clients.
BR Silvio
Return to “OmniSwitch 6360”
