need actis quote for vowlan requirement
Alcatel Configuration Tool for International Sales -all ACTIS related topics, how-to's, tips and tricks.
penny
Post by penny »
customer using oxe ip media gateway wants to expand existing pabx to 50 wlan points and 50 vowlan points. we did survey requires 3 wlan switches and 15 access points and 3 access points with omni directional antennas. so i am planning for new release sets 310,610 series with out svp server. wlan switch requires minium 8 poe wlan ports and supports firewall & web portal license.
how to configure in actis above requirement? how to choose required wlan switch with additional features?
Shotz
Re: need actis quote for vowlan requirement
Post by Shotz »
What are you doing?
Voice?
Date?
Voice and Data?
Why do you need 3 WLAN Switches?
OmniAccess 4324 will support 48 AP's. 24 directly connected and it has 24 PoE 10/100 ethernet ports.
How do you know you need 50 AP's? That is a pretty exact amount.
Have you done a site survey? Have you done a predicitive Site Survey?
What do your customers want? 802.11a or 802.11b/g or both?
I would check on the Business Partner site in order to better fill out Actis. There should be a presentation on Actis on there.
Good Luck.
Return to “Actis”
