INVALID NUMBER FORMAT on E-1 to SIP transit call
ahqswitchroom4466
Hello sir
any one help me, when call from E-1 to SIP trunk using our pbx transit. t3 show INVALID NUMBER FORMAT.
Our E-1 connection using ABCF (QSIG-GF), Prefix using Routing Number and SIP Trunk ABCF (SIP) Prefix using ARS ARS Profesonal trg Size with overlap.
SIP to E-1 call communication ok but SIP to E-1 call show INVALID NUMBER FORMAT.
Md Afzal Hossain
System Admin
Md Afzal Hossain
System Admin
Re: INVALID NUMBER FORMAT on E-1 to SIP transit call
Show please whole t3 trace.
ahqswitchroom4466
#vad
Traces Analyser activated
mtracer started ...
(200552:000001:25787) MTRACER host (172.16.0.4, ahqoxe1), version: R100.0-n1.291-70-in-c0s1
(200552:000001:25787) MTRACER num: 007, time: 2024/08/27 00:42:07, loss: 0%
| (200571:000002:03723) Concatenated-Physical-Event :
| long: 137 desti: 0 source: 0 cryst: 3 cpl: 11 us: 0 term: 1 type a5
| tei: 0 >>>> message received : SETUP [05] Call ref : 3a e0
| IE:[18] CHANNEL (l=3) a1 83 88 -> T2 : B channel 8 preferred
| IE:[1c] FACILITY (l=75)
| [91] Discriminator of supplementary service applications
| [aa] NFE (l=6):
| [80] Source Entity (l=1) End_PTNX
| [82] Destination Entity (l=1) End_PTNX
| [8b] Interpretation APDU (l=1): DISCARD (0)
| [a1] INVOKE (l=16):
| Invoke Ident. : 2ee0 (12000)
| OP: ECMA RO_CALLING_NAME (0)
| [80] Name presentation allowed (l=4) '7060'
| [a1] INVOKE (l=43):
| Invoke Ident. : 0001 (1)
| OP: ALCATEL RO_CLASSMARKS (1)
| [30] Sequence (l=30)
| [80] Feature identifier (l=5) 44 04 70 1f 20
| [82] Cug (l=1) 00
| [ab] Sequence of Project data (l=18)
| [30] Sequence (l=16)
| OP :RO_CLASSMARKS_SUPPLEMENTARY_INFO_1 (134615530)
| [30] Sequence (l=10)
| [80] Trunk group feature (l=5) 06 00 00 20 04
| [83] Current entity (l=1) 01
| IE:[6c] CALLING_NUMBER (l=6) -> 09 81 Num : 7060
| IE:[70] CALLED_NUMBER (l=11) -> 80 Num : 9459010017
| IE:[7d] HLC (l=2) 91 81
| [95] Locking shift. codeset : 5
| IE:[31] EI_TRANSIT_COUNTER (l=1) 81
| IE:[32] EI_PARTY_CATEGORY (l=1) -> EXTENSION (1)
| (200571:000005:03689) 3689: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| long: 23 desti: 0 source: 15 cryst: 3 cpl: 11 us: 8 term: 1 type a5
| tei: 0 <<<< message sent : SETUP ACK [0d] Call ref : ba e0
| (200720:000006:03689) 3689: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| long: 22 desti: 0 source: 15 cryst: 3 cpl: 11 us: 8 term: 1 type a5
| tei: 0 <<<< message sent : DISCONNECT [45] Call ref : ba e0
| IE:[08] CAUSE (l=2) 80 9c -> [9c] INVALID NUMBER FORMAT
| (200721:000007:03723) Concatenated-Physical-Event :
| long: 23 desti: 0 source: 0 cryst: 3 cpl: 11 us: 0 term: 1 type a5
| tei: 0 >>>> message received : RELEASE [4d] Call ref : 3a e0
| IE:[08] CAUSE (l=3) 80 90 80 -> [90] NORMAL CALL CLEARING
| (200721:000008:03689) 3689: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| tei: 0 <<<< message sent : REL COMP [5a] Call ref : ba e0
External Getway
Node Number (reserved) : 1 │
│ Instance (reserved) : 1 │
│ SIP External Gateway ID : 4 │
│ Gateway Name : VSAT │
│ SIP Remote domain : 10.100.20.30 │
│ PCS IP Address : ----------------------------------------------- │
│ SIP Port Number : 5060 │
│ Transport type + UDP │
│ Belonging Domain : -------------------------------------------------- │
│ Registration ID : -------------------------------------------------- │
│ Registration ID P_Asserted + False │
│ Registration timer : 0 │
│ SIP Outbound Proxy : -------------------------------------------------- │
│ Supervision timer : 0 │
│ Trunk group number : 245 │
│ Pool Number : -1 │
│ Outgoing realm : -------------------------------------------------- │
│ Outgoing username : -------------------------------------------------- │
│ Outgoing Password : -------------------- │
│ Confirm : -------------------- │
│ Incoming username : -------------------------------------------------- │
│ RFC 3325 supported by the distant + True │
│ DNS type + DNS A │
│ SIP DNS1 IP Address : ----------------------------------------------- │
│ SIP DNS2 IP Address : ----------------------------------------------- │
│ SDP in 18x + True │
│ Minimal authentication method + None │
│ INFO method for remote extension + False │
│ To EMS + False │
│ SRTP + RTP only │
│ Ignore inactive/black hole + True │
│ Contact with IP address + False │
│ Dynamic Payload type for DTMF : 101 │
│ Outbound Calls 100 REL + Supported │
│ Incoming Calls 100 REL + Not Requested │
│ Gateway type + Standard type │
│ Re-Trans No. for REGISTER/OPTIONS : 2 │
│ P-Asserted-ID in Calling Number + True │
│ Trusted P-Asserted-ID header + True │
│ Diversion Info to provide via + History Info │
│ Proxy identification on IP address + False │
│ Outbound calls only + False │
│ SDP relay on Ext. Call Fwd + Default │
│ SDP Transparency Override + False │
│ RFC 5009 supported / Outbound call + Not Supported │
│ Nonce caching activation + NO │
│ FAX Procedure Type + T38 only │
│ DNS SRV/Call retry on busy server : 0 │
│ Unattended Transfer for RSI + NO │
│ Redirection functionality + NO │
│ Attended Transfer + NO │
│ Send BYE on REFER + YES │
│ Support Redirection response + NO │
│ OPTIONS required + YES │
│ Support UTF8 characters set + NO │
│ Support CSTA User-to-User + NO │
│ DDI destination number + ReqURI │
│ Video Support Profile + Not Supported │
│ UPDATE in Allow header/INVITE + Optional │
│ RFC 4904 supported + NO │
│ Bulk registration (RFC 6140) + NO │
│ RFC3264 m-line + True │
│ Sendonly for hold + False │
│ In Band DTMF + NO │
│ SIP trunk Recording + NO │
│ Send user name in SIP + User name else user number │
│ Session Timer : 1800 │
│ Min Session Timer : 900 │
│ Session Timer Method + UPDATE │
│ Allow Direct RTP + True │
│ IP Domain : 0 │
│ Trusted From header + True │
│ Support Re-invite without SDP + True │
│ Type of codec negotiation + Default │
mtracer started ...
| [aa] NFE (l=6):
| [a1] INVOKE (l=16):
| [a1] INVOKE (l=43):
| [82] Cug (l=1) 00
External Getway
│ To EMS + False │
│ SRTP + RTP only │
│ IP Domain : 0 │
Md Afzal Hossain
System Admin
Md Afzal Hossain
System Admin
- frank
What does 9459010017 relates to?
ahqswitchroom4466
945 is our prefix. and start cucm telephone number is 945XXXXXXX. i am using ars here is full configuration.. where i missed.
┌─Review/Modify: Trunk Groups───────────────────────────────────────────────────────┐
│ Trunk Group ID : 245 │
│ Trunk Group Type + T2 │
│ Trunk Group Name : VSAT │
│ UTF-8 Trunk Group Name : ------------------------------------------- │
│ Number Compatible With : -1 │
│ Remote Network : 15 │
│ Shared Trunk Group + False │
│ Special Services + Nothing │
│ Node number : 1 │
│ Transcom Trunk Group + False │
│ Auto.reserv.by Attendant + False │
│ Overflow trunk group No. : -1 │
│ Tone on seizure + False │
│ Private Trunk Group + True │
│ Q931 Signal variant + ABC-F │
│ SS7 Signal variant + No variant │
│ Number Of Digits To Send : 15 │
│ Channel selection type + Quantified │
│ Auto.DTMF dialing on outgoing call + NO │
│ T2 Specification + SIP │
│ Homogenous network for direct RTP + NO │
│ Public Network COS : 31 │
│ DID transcoding + False │
│ Can support UUS in SETUP + True │
│ Associated Ext SIP gateway : 4 │
│ Implicit Priority │
│ Activation mode : 0 │
│ Priority Level : 0 │
│ Preempter + NO │
│ Incoming calls Restriction COS : 10 │
│ Outgoing calls Restriction COS : 10 │
│ Callee number mpt1343 + NO │
│ Overlap dialing + YES │
│ Call diversion in ISDN + NO │
┌─Review/Modify: Trunk Group──────────────────────────────────────────────┐
│ Public Network Ref. : ------ │
│ VG for non-existent No. + YES │
│ Entity Number : 0 │
│ Supervised by Routing + NO │
│ VPN Cost Limit for Incom.Calls : 0 │
│ Immediate Trk Listening if VPNCall + YES │
│ VPN TS % : 50 │
│ CSTA-Monitored + NO │
│ Max.% of trunks out CCD : 0 │
│ Ratio analog.to ISDN cost : ------ │
│ TS Distribution on Accesses + YES │
│ Quality profile for voice over IP + Profile #1 │
│ Use of volume in system + YES │
│ Announcement for dial tone + NO │
│ Announcement for Ring tone + NO │
│ Reroute Anonymous Calls to Entity + NO │
│ Called Number Storage + NO │
│ End-to-end dialing + NO │
│ DTMF end-to-end signal. + NO │
│ Trunk group used in DISA + NO │
│ DISA Secret Code : ---- │
│ Routing To Manager + NO │
│ Trunk COS : 31 │
│ Sending of Progress message + YES │
│ No. of digits unused (ISDN) : 0 │
│ B Channel Choice + YES │
│ Channels: Attendant Control (Rsvd) : 0 │
│ Redirection For ACD (Dissuasion) + NO │
│ DTO joining + NO │
│ Consultation Call On B Channel + NO │
│ Automated Attendant + NO │
│ Calling party Rights COS : 0 │
│ TS Overflow + YES │
│ Number To Be Added : -------- │
│ Charge Calling And ADN Creation + YES │
│ Logical Channel + 1__15 & 17__31 │
│ Use Split Access + NO │
│ Heterogeneous Remote Network + NO │
│ COS Restrictions - Barring mode + Not Restricted / Not barred │
│ ARS Class of service : 31 │
│ External Access Server + NO │
│ CSTA Tracking MCDU Trk : -------- │
│ IE External Forward + None │
│ Max ABCF-IP and SIP connections : 0 │
┌─Review/Modify: Trunk group NPD selector────────────┐
│ Public NPD ID : 2 │
│ Private NPD ID : 0 │
│ Management Mode + Automatic │
│ Public DID transcoding + False │
┌─Review/Modify: Prefix Plan──────────────────────────────────────────────┐
│ Number : 945 │
│ Prefix Meaning + ARS Prof.Trk Grp Seiz.with overlap │
│ Discriminator No. : 5 │
┌─Review/Modify: Discriminator Rule──────────────────────────────────────────────────────────────────┐
│ Call Number : 9 │
│ Area Number : 1 │
│ ARS Route List Number : 5 │
│ Schedule Number : -1 │
│ Number of Digits : 10 │
┌─Review/Modify: Numbering Command Table─────────────────────────────────────────┐
│ Table ID : 5 │
│ Carrier Reference : 0 │
│ Command : I │
┌─Review/Modify: Time-based Route List───────────────────────────────────────┐
│ ARS Route list : 5 │
│ Time-based Route List ID : 1 │
│ Time-based Route │
│ [ Add ] [ Remove ] [ Next ] [Previous] │
│ Route Number : 1 │
│ Waiting Cost Limit : -1 │
│ Stopping Cost Limit : -1 │
┌─Review/Modify: ARS Route───────────────────────────────────────────────────┐
│ Route : 1 │
│ Name : VSAT │
│ Trunk Group Source + Route │
│ Trunk Group : 245 │
│ No.Digits To Be Removed : 0 │
│ Digits To Add : 945 │
│ Numbering Command Tabl. ID : 5 │
│ VPN Cost Limit : 0 │
│ Protocol Type + ABC_F │
│ NPD identifier : 44 │
│ Route Type + Private │
│ ATM Address ID : -1 │
│ Preempter + False │
│ Quality │
│ Quality + Speech │
┌─Review/Modify: Numbering Plan Description (NPD)──────────────────────┐
│ Description identifier : 44 │
│ Name : sip │
│ Calling Numbering plan ident. + Unknown │
│ Called numbering plan ident. + Unknown │
│ Authorize personal calling num use + False │
│ Install. number source + Entity source │
│ Default number source + Entity source │
│ Called DID identifier : -1 │
│ Calling/Connected DID identifier : -1 │
┌─Review/Modify: Entities───────────────────────────────────────────────────────────────────────────────┐
│ Entity Number : 5 │
│ Name : VSAT │
│ UTF-8 Name : --------------------------------------------------------------- │
│ Attendant Group Manager : -1 │
│ Priority + YES │
│ Emergency call to attd + YES │
│ Traffic Overflow + Disallowed │
│ Installation No. (ISDN) : ------------------------------ │
│ Supplement.Install.No. (ISDN) : ------------------------------ │
│ Caller ID Secret + No │
│ AdvOfCharg2 requests (AOC2) + NO │
│ AdvOfCharg3 requests (A0C3) + NO │
│ Auto. Locking : 0 │
│ Voice Mail Box No.for attendt : -------- │
│ External Callback Table : 0 │
│ Call Distribution │
│ Overflow Routing No. : -------- │
│ Forwarding on routing + YES │
│ 1st Night Routing : -------- │
│ 2nd Night Routing : -------- │
│ 3nd Night Routing : -------- │
┌─Review/Modify: Discriminator Selector──────────────┐
│ Discriminator 00 : 0 │
│ Discriminator 01 : 1 │
│ Discriminator 02 : 0 │
│ Discriminator 03 : 0 │
│ Discriminator 04 : 0 │
│ Discriminator 05 : 5 │
│ Discriminator 06 : 0 │
│ Discriminator 07 : 0 │
│ Node number : 1 │
│ Preempter + NO │
│ VPN TS % : 50 │
│ Trunk COS : 31 │
│ Number : 945 │
│ Call Number : 9 │
│ Area Number : 1 │
│ Table ID : 5 │
│ Command : I │
│ Route : 1 │
│ Name : VSAT │
│ Quality │
│ Name : sip │
│ Name : VSAT │
│ Priority + YES │
Md Afzal Hossain
System Admin
Md Afzal Hossain
System Admin
when sip or transit call remote network in trunkgp should different from 15
why complicate you life 945 is a part of the whole number of Cucm why do you use it as ars prefix 945 should be routing number pointing to your cucm network
EXEMPLE for calling 38982000 wich is a remote network user i use
Node Number (reserved) : 1 x
x Instance (reserved) : 1 x
x Number : 3898 x
x x
x Prefix Meaning + Routing No. x
x Network Number : 14 x
x Node Number/ABC-F Trunk Group : 1799 x
x Number of Digits : 8 x
x Number With Subaddress (ISDN) + NO x
x Default X25 ID.pref. + NO
x Number : 3898 x
x x
ahqswitchroom4466
our cucm pabx all telephone number is 10 digit. so i can't using routing no. all number 9459010017 like this..
Md Afzal Hossain
System Admin
Md Afzal Hossain
System Admin
- frank
can you add a sip trace with that?
motortrace 2
killall sipmotor
traced
motortrace 2
killall sipmotor
traced
ahqswitchroom4466
When i call from our other pabx.. i can't find any log from mototrace1,2,3. But t3 show
our other pabx (Milte Mx-One, Bussiness and Alcatel OXE- R12.5) connected by E-1 (ABCF: QSIG-GF). Mitel use Qsig-ETSI.
Other PABX==E1==>My PABX==SIP==>CUCM ---->Not working
CUCM==SIP==>My PABX==E1==>Other PABX ---->Working
My PABX==SIP==>CUCM ---->Working
My PABX all extension is 4 figure as like 2000 to 8999. and our all prefix code is 902 to 999.
Our all other pabx extension same as my pabx
CUCM all extension is 10 figure as like 9459010017, 9459330002.
This is our local call tarce
1725043803 -> Sat Aug 31 00:50:03 2024 [ipc_thread] Normal case : evt 10752
Sat Aug 31 00:50:03 2024 [ipc_thread] IPC Thread : Ipc reception 10744.
Sat Aug 31 00:50:03 2024 [ipc_thread] IPC Thread : TCL thread signaled.
Sat Aug 31 00:50:03 2024 [exec_ipc] in 10733.
Sat Aug 31 00:50:03 2024 [display_ipc_in] ------------ Begin ---------------
Sat Aug 31 00:50:03 2024 neqt : 15672 Id : -1
Sat Aug 31 00:50:03 2024 INVITE
Sat Aug 31 00:50:03 2024 REQUEST URI : <> 9459010017@10.100.20.30:5060 ; user=phone
Sat Aug 31 00:50:03 2024 FROM : <AHQ SWITCH R> 4466@172.16.0.7:5060 ; user=phone
Sat Aug 31 00:50:03 2024 TO : <> 9459010017@10.100.20.30:5060 ; user=phone
Sat Aug 31 00:50:03 2024 CAC : 0
Sat Aug 31 00:50:03 2024 neqt CAC : -1
Sat Aug 31 00:50:03 2024 CAC-CSBU info : UNKNOWN
Sat Aug 31 00:50:03 2024 CLIR : 0
Sat Aug 31 00:50:03 2024 SDP :
Sat Aug 31 00:50:03 2024 ADDRESS : 172.16.0.17 :32692
Sat Aug 31 00:50:03 2024 ALGOS :
Sat Aug 31 00:50:03 2024 PCMA
Sat Aug 31 00:50:03 2024 PCMU
Sat Aug 31 00:50:03 2024 G729
Sat Aug 31 00:50:03 2024 101
Sat Aug 31 00:50:03 2024 DIRECTION : SEND & RECEIVE
Sat Aug 31 00:50:03 2024 video index : 0
Sat Aug 31 00:50:03 2024 crypto index : 0
Sat Aug 31 00:50:03 2024 N_GW_EXT : 4
Sat Aug 31 00:50:03 2024 [display_ipc_in] ------------- End ----------------
Sat Aug 31 00:50:03 2024 [CMotorCallManager::onIncomingEvent] an event 10752 arrived on the eqt 15672 -1.
Sat Aug 31 00:50:03 2024 [CMotorCallManager::callFactory].
Sat Aug 31 00:50:03 2024 1104[CMotorCall::setSessionTimer] main gw sessionTimer=2000
1725043803 -> Sat Aug 31 00:50:03 2024 [CMotorCall :: CMotorCall()] Oxe_Version_Name = OmniPCX Enterprise R100.0 n1.291.70
Sat Aug 31 00:50:03 2024 [CMotorCallManager::callFactory]=8b07cc0.
Sat Aug 31 00:50:03 2024 [CMotorCallManager::insertCallwithEqt] CMotorCall 15672 inserted.
Sat Aug 31 00:50:03 2024 1104[CMotorCall::setExtGw] -1->4
Sat Aug 31 00:50:03 2024 1104[CMotorCall::setSessionTimer] gw=4 sessionTimer=1800
Sat Aug 31 00:50:03 2024 1104[CMotorCall::inviteBuildAurlWithBelongingDomain] extGw=4
Sat Aug 31 00:50:03 2024 1104[CMotorCall::inviteBuildAurlWithoutBelongingDomain] P-Asserted-Identity: "AHQ SWITCH R" <sip:4466@172.16.0.7:5060;user=phone>
Sat Aug 31 00:50:03 2024 1104[CMotorCall::setFilterUsedMode] To be traced = 0
Sat Aug 31 00:50:03 2024 [CMotorCallManager::onIncomingEvent] state = INITIAL_STATE.
Sat Aug 31 00:50:03 2024 [onIncomingEvent] INVITE arrived.
Sat Aug 31 00:50:03 2024 [receiveInviteEvent] Call: eqt: 15672 INITIAL_STATE received an event.
Sat Aug 31 00:50:03 2024 1104[CMotorCall::emitInviteMessage] begin. size=652 call_type: 0
Sat Aug 31 00:50:03 2024 1104[CMotorCall::setExtGw] 4->4
Sat Aug 31 00:50:03 2024 1104[CMotorCall::getUserType] extGw=4.
Sat Aug 31 00:50:03 2024 1104[CMotorCall::emitInviteMessage] From: "AHQ SWITCH R" <sip:4466@172.16.0.7:5060;user=phone>
1725043803 -> Sat Aug 31 00:50:03 2024 1104[CMotorCall::emitInviteMessage] reqUri :sip:9459010017@10.100.20.30:5060;user=phone
Sat Aug 31 00:50:03 2024 [issipisdn_extgw] ABCF ExtGW
Sat Aug 31 00:50:03 2024 1104[CMotorCall::emitInviteMessage] To: <sip:9459010017@10.100.20.30:5060;user=phone>
Sat Aug 31 00:50:03 2024 [isUserRegistred] getRegistration=9459010017.
Sat Aug 31 00:50:03 2024 [isUserRegistred] try with alias.
Sat Aug 31 00:50:03 2024 [getUrlByAlias] user=9459010017.
Sat Aug 31 00:50:03 2024 [getUrlByAlias] domain=10.100.20.30.
Sat Aug 31 00:50:03 2024 [getUrlByAlias] NOK
Sat Aug 31 00:50:03 2024 [isUserRegistred] result=-1.
Sat Aug 31 00:50:03 2024 [convertIPStrIntoTuipv] 10.100.20.30 => 10.100.20.30
Sat Aug 31 00:50:03 2024 [isIpAddressType] YES.
Sat Aug 31 00:50:03 2024 The user is ipadd not in any Domain range return state as -1
Sat Aug 31 00:50:03 2024 [CMngData::getStackPort] >>>>> transportProtocol: 0, isMTLS: 0, m_uStackSecureMtlsPort: 6261, m_uStackSecurePort: 5061, m_uStackUnsecurePort 5060
Sat Aug 31 00:50:03 2024 [CMngData::getStackPort] >>>>> port: 5060
Sat Aug 31 00:50:03 2024 1104[CMotorCall::buildContactInvite] Contact: sip:4466@172.16.0.7:5060
Sat Aug 31 00:50:03 2024 1104[CMotorCall::isExtGwTLSwithREINVITE] ExtGw NOT manged with TLS and refresh REINVITE
Sat Aug 31 00:50:03 2024 1104[CMotorCall::inviteBuildSessionTimer] uacGatewayMode=1 uacRefresher=1.
1725043803 -> Sat Aug 31 00:50:03 2024 1104[CMotorCall::setAudioMediaToSdp] appendMediaDescription ok.
Sat Aug 31 00:50:03 2024 1104[CMotorCall::new_determineTargetsForTheRequest] is not Responsible For This URI.
Sat Aug 31 00:50:03 2024 1104[CMotorCall::makeInitialMotorRequest] target is not the local node.
Sat Aug 31 00:50:03 2024 1104[CMotorCall::makeInitialMotorRequest] nb contacts=1.
Sat Aug 31 00:50:03 2024 1104[CMotorCall::makeInitialMotorRequest] contact : sip:9459010017@10.100.20.30:5060;user=phoneSat Aug 31 00:50:03 2024 1104[CMotorCall::makeInitialMotorRequest] nb available licenses=600 .
Sat Aug 31 00:50:03 2024 [CGWMngData::isMainServer] CPU is MAIN.
Sat Aug 31 00:50:03 2024 SEND MESSAGE TO NETWORK (10.100.20.30:5060 [UDP]) (BUFF LEN = 1125)
INVITE sip:9459010017@10.100.20.30:5060;user=phone SIP/2.0
Allow: INVITE, ACK, CANCEL, BYE, PRACK, NOTIFY, REFER, SUBSCRIBE, OPTIONS, UPDATE, INFO
Supported: replaces,timer,path,100rel
User-Agent: OmniPCX Enterprise R100.0 n1.291.70
Session-Expires: 1800;refresher=uac
Min-SE: 900
Content-Type: application/sdp
From: "AHQ SWITCH R" <sip:4466@172.16.0.7:5060;user=phone>;tag=d618b0effb8036abfce113aff58cd778
Contact: <sip:4466@172.16.0.7:5060;transport=UDP>
Call-ID: 5ec4a5f8265a66f5eac0b1f599aa3b8a@172.16.0.7
CSeq: 168989904 INVITE
Via: SIP/2.0/UDP 172.16.0.7;branch=z9hG4bK0f4a4b1533e93688c00e15540d7927c4
Max-Forwards: 70
Content-Length: 338
v=0
o=OXE 1725043803 1725043803 IN IP4 172.16.0.7
s=abs
c=IN IP4 172.16.0.17
t=0 0
m=audio 32692 RTP/AVP 8 0 18 101
a=sendrecv
a=rtpmap:8 PCMA/8000
a=ptime:20
a=maxptime:30
a=rtpmap:0 PCMU/8000
a=ptime:20
a=maxptime:30
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=ptime:20
a=maxptime:40
a=rtpmap:101 telephone-event/8000
1725043803 -> Sat Aug 31 00:50:03 2024 [convertIPStrIntoTuipv] 10.100.20.30 => 10.100.20.30
Sat Aug 31 00:50:03 2024 1104[CMotorCall::setCurrentState] NOE-SIP : sendBackupUpdate Msg not sent to twin CS
Sat Aug 31 00:50:03 2024 NOE-SIP : StandByCallCreation not sent to twin CS
Sat Aug 31 00:50:03 2024 [onIncomingEvent] CallID inserted.
Sat Aug 31 00:50:03 2024 [exec_ipc] in end 10733.
Sat Aug 31 00:50:03 2024 RECEIVE MESSAGE FROM NETWORK (10.100.20.30:5060 [UDP])
SIP/2.0 100 Trying
Date: Fri, 30 Aug 2024 20:09:36 GMT
Allow-Events: presence
Content-Length: 0
Sat Aug 31 00:50:03 2024 102 [CCallManager::onIncomingResponse]
Sat Aug 31 00:50:03 2024 [receiveInformationalMessage] Call: 5ec4a5f8265a66f5eac0b1f599aa3b8a@172.16.0.7 eqt: 15672 PROCEEDING_STATE received a message.
Sat Aug 31 00:50:03 2024 [receiveInformationalMessage] 0 AlertInfo header(s) found
1725043803 -> Sat Aug 31 00:50:03 2024 [CPoceedingState::receiveInformationalMessage]-->nof of PEM hdrs 0
Sat Aug 31 00:50:03 2024 [receiveInformationalMessage] No P-Early-Media header received
Sat Aug 31 00:50:03 2024 [receiveInformationalMessage] is in the else part of SDP not present
1725043803 -> Sat Aug 31 00:50:03 2024 RECEIVE MESSAGE FROM NETWORK (10.100.20.30:5060 [UDP])
SIP/2.0 180 Ringing
To: <sip:9459010017@10.100.20.30:5060;user=phone>;tag=5730636~f12da00c-7296-4fdc-9063-32b2ac5f883d-18779763
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
Server: Cisco-CUCM12.5
Call-Info: <urn:x-cisco-remotecc:callinfo>;x-cisco-video-traffic-class=DESKTOP
Supported: X-cisco-srtp-fallback
Supported: Geolocation
Session-ID: 5fd23c8600105000a000d0ec358402c1;remote=9ae73d63f628e4d0645d279ab5730636
P-Asserted-Identity: "Hub Sta Op/Complain" <sip:9459010017@10.100.20.30>
Remote-Party-ID: "Hub Sta Op/Complain" <sip:9459010017@10.100.20.30>;party=called;screen=yes;privacy=off
Contact: <sip:9459010017@10.100.20.30:5060>;+u.sip!devicename.ccm.cisco.com="SEPD0EC358402C1"
Content-Length: 0
1725043804 -> Sat Aug 31 00:50:03 2024 [receiveInformationalMessage] Call: 5ec4a5f8265a66f5eac0b1f599aa3b8a@172.16.0.7 eqt: 15672 PROCEEDING_STATE received a message.
Sat Aug 31 00:50:03 2024 [convertCSipURLIntoSipuri] uri = sip:9459010017@10.100.20.30.
Sat Aug 31 00:50:03 2024 1104[emitEventToMonitel] CAC = 0 eqtCAC = -1
Sat Aug 31 00:50:03 2024 1104[emitEventToMonitel] cacUsed=0 eqtCac=-1
Sat Aug 31 00:50:03 2024 1104[emitEventToMonitel] displayIPCMessageOut
Sat Aug 31 00:50:03 2024 ** SIP TRUNKING **
Sat Aug 31 00:50:03 2024 [sendLgEvtSip] Event sent on eqt : 15672 Id :-1
Sat Aug 31 00:50:03 2024 [display_ipc_out] ------------ Begin ---------------
Sat Aug 31 00:50:03 2024 Id : -1
Sat Aug 31 00:50:03 2024 INFORMATIONAL
Sat Aug 31 00:50:03 2024 xx : 80
Sat Aug 31 00:50:03 2024 RELATIVE REQUEST : INVITE
Sat Aug 31 00:50:03 2024 Allow Update : 0
Sat Aug 31 00:50:03 2024 [display_ipc_out] ------------- End ----------------
Sat Aug 31 00:50:04 2024 [ipc_thread] Normal case : evt 10756
Sat Aug 31 00:50:04 2024 [ipc_thread] IPC Thread : Ipc reception 10744.
Sat Aug 31 00:50:04 2024 [ipc_thread] IPC Thread : TCL thread signaled.
Sat Aug 31 00:50:04 2024 [exec_ipc] in 10733.
1725043804 -> Sat Aug 31 00:50:04 2024 [display_ipc_in] ------------ Begin ---------------
Sat Aug 31 00:50:04 2024 neqt : 15672 Id : -1
Sat Aug 31 00:50:04 2024 CANCEL
Sat Aug 31 00:50:04 2024 [display_ipc_in] ------------- End ----------------
Sat Aug 31 00:50:04 2024 [CMotorCallManager::onIncomingEvent] an event 10756 arrived on the eqt 15672 -1.
Sat Aug 31 00:50:04 2024 [CMotorCallManager::onIncomingEvent] state = PROCEEDING_STATE.
Sat Aug 31 00:50:04 2024 [onIncomingEvent] CANCEL arrived.
Sat Aug 31 00:50:04 2024 [receiveCancelEvent] Call: 5ec4a5f8265a66f5eac0b1f599aa3b8a@172.16.0.7 eqt: 15672 PROCEEDING_STATE received an event.
Sat Aug 31 00:50:04 2024 [receiveCancelEvent] incoming call.
Sat Aug 31 00:50:04 2024 [issipisdn_extgw] ABCF ExtGW
Sat Aug 31 00:50:04 2024 1104[CMotorCall::emitCancelMessage] reason cause=-1, seplos=0, isdn=0
Sat Aug 31 00:50:04 2024 1104[CMotorCall::makeFinalMotorRequest] nb contact=1 max=1 cancelled.
Sat Aug 31 00:50:04 2024 SEND MESSAGE TO NETWORK (10.100.20.30:5060 [UDP]) (BUFF LEN = 489)
CANCEL sip:9459010017@10.100.20.30:5060;user=phone SIP/2.0
CSeq: 168989904 CANCEL
Max-Forwards: 70
Content-Length: 0
1725043804 -> Sat Aug 31 00:50:04 2024 [convertIPStrIntoTuipv] 10.100.20.30 => 10.100.20.30
Sat Aug 31 00:50:04 2024 [isIpAddressType] YES.
Sat Aug 31 00:50:04 2024 1104[CMotorCall::setCurrentState] NOE-SIP : sendBackupUpdate Msg not sent to twin CS
Sat Aug 31 00:50:04 2024 [exec_ipc] in end 10733.
Sat Aug 31 00:50:04 2024 RECEIVE MESSAGE FROM NETWORK (10.100.20.30:5060 [UDP])
SIP/2.0 200 OK
Date: Fri, 30 Aug 2024 20:09:37 GMT
Content-Length: 0
Sat Aug 31 00:50:04 2024 [CMngData::getStackPort] >>>>> transportProtocol: 0, isMTLS: 0, m_uStackSecureMtlsPort: 6261, m_uStackSecurePort: 5061, m_uStackUnsecurePort 5060
Sat Aug 31 00:50:04 2024 [CMngData::getStackPort] >>>>> port: 5060
Sat Aug 31 00:50:04 2024 102 [CCallManager::onIncomingResponse]
Sat Aug 31 00:50:04 2024 [receiveSuccessfulMessage] Call: 5ec4a5f8265a66f5eac0b1f599aa3b8a@172.16.0.7 eqt: 15672 CANCEL_PROCESSING_STATE received a message.
Sat Aug 31 00:50:04 2024 1104[emitEventToMonitel] CAC = 0 eqtCAC = -1
Sat Aug 31 00:50:04 2024 1104[emitEventToMonitel] cacUsed=0 eqtCac=-1
Sat Aug 31 00:50:04 2024 1104[emitEventToMonitel] displayIPCMessageOut
1725043804 -> Sat Aug 31 00:50:04 2024 ** SIP TRUNKING **
Sat Aug 31 00:50:04 2024 [sendLgEvtSip] Event sent on eqt : 15672 Id :-1
Sat Aug 31 00:50:04 2024 [display_ipc_out] ------------ Begin ---------------
Sat Aug 31 00:50:04 2024 Id : -1
Sat Aug 31 00:50:04 2024 SUCCESSFUL
Sat Aug 31 00:50:04 2024 xx : 0
Sat Aug 31 00:50:04 2024 RELATIVE REQUEST : CANCEL
Sat Aug 31 00:50:04 2024 CAC-CSBU info : UNKNOWN
Sat Aug 31 00:50:04 2024 CLIR : 27
Sat Aug 31 00:50:04 2024 COLP : 64
Sat Aug 31 00:50:04 2024 [display_ipc_out] ------------- End ----------------
SIP/2.0 487 Request Cancelled
Content-Length: 0
1725043804 -> Sat Aug 31 00:50:04 2024 SEND MESSAGE TO NETWORK (10.100.20.30:5060 [UDP]) (BUFF LEN = 453)
ACK sip:9459010017@10.100.20.30:5060;user=phone SIP/2.0
CSeq: 168989904 ACK
Max-Forwards: 70
Content-Length: 0
Sat Aug 31 00:50:04 2024 [CForkedBranch::setFinalResponse] response=487.
Sat Aug 31 00:50:04 2024 1104[CMotorCall::responseToInviteOrCancel] no response to the CH m_cancelSent=1.
Sat Aug 31 00:50:04 2024 1104[CMotorCall::responseToInviteOrCancel] all responses are received 1.
Sat Aug 31 00:50:04 2024 1104[CMotorCall::chooseBestResponse] pForkedBranch=0x8b0c8c0 iResponseCode=2000.
Sat Aug 31 00:50:04 2024 1104[CMotorCall::chooseBestResponse] last iResponseCode=487.
Sat Aug 31 00:50:04 2024 [CForkedBranch::setFinalResponse] pResponse=0x8b10110.
Sat Aug 31 00:50:04 2024 1104[CMotorCall::chooseBestResponse] next branch.
Sat Aug 31 00:50:04 2024 [receiveRequestFailureMessage] Call: 5ec4a5f8265a66f5eac0b1f599aa3b8a@172.16.0.7 eqt: 15672 CANCEL_PROCESSING_STATE received a message.
1725043804 -> IsIP_Phone neqt(1586) false
1725043804 -> Sat Aug 31 00:50:04 2024 1104[emitEventToMonitel] CAC = 0 eqtCAC = -1
Sat Aug 31 00:50:04 2024 [ipc_thread] Normal case : evt 10773
Sat Aug 31 00:50:04 2024 REQUEST FAILURE
Sat Aug 31 00:50:04 2024 xx : 87
Sat Aug 31 00:50:04 2024 RELATIVE REQUEST : INVITE
Sat Aug 31 00:50:04 2024 1104[CMotorCall::emitAckMessage]
Sat Aug 31 00:50:04 2024 1104[CMotorCall::unRegister] Remove eqt : 15672 diag : -1 from the map.
Sat Aug 31 00:50:04 2024 [CMotorCallManager::eraseCallwithEqt] erase 15672 -1.
Sat Aug 31 00:50:04 2024 [receiveRequestFailureMessage] not handled in this state => kill session.
Sat Aug 31 00:50:04 2024 [CMotorCallManager::onNotifyCallClosed] Call : 5ec4a5f8265a66f5eac0b1f599aa3b8a@172.16.0.7 is closed.
Sat Aug 31 00:50:04 2024 [CMotorCallManager::onNotifyCallClosed] Remove eqt from the map.
1725043805 -> is_my_node_in_campus false
1725043805 -> Sat Aug 31 00:50:04 2024 1104[CMotorCall::setCurrentState] NOE-SIP : sendBackupUpdate Msg not sent to twin CS
Sat Aug 31 00:50:04 2024 SIP EQT RELEASED
Sat Aug 31 00:50:04 2024 [CMotorCallManager::onIncomingEvent] an event 10773 arrived on the eqt 15672 -1.
Sat Aug 31 00:50:04 2024 [CMotorCallManager::onIncomingEvent] NO call with eqt: 15672 -1 to release.
Sat Aug 31 00:50:04 2024 is_a_JONCT
Sat Aug 31 00:50:04 2024 is_a_JONCT call with SIP
Sat Aug 31 00:50:04 2024 [CMotorCallManager::onIncomingEvent] call not available just send SIP_EQT_RELEASE_ACK
Sat Aug 31 00:50:04 2024 SIP_EQT_RELEASE_ACK
Sat Aug 31 00:50:05 2024 [fnInit] *************************** Init timeout.
Sat Aug 31 00:50:05 2024 [fnInit] treatTimeout.
Sat Aug 31 00:50:05 2024 [CMotorInitTimerContext::treatTimeout] emitRegisterMessage gw=10.
Sat Aug 31 00:50:05 2024 [CMotorInitTimerContext::start] delay =6000 gw 10.
Min-SE: 900
Max-Forwards: 70
Content-Length: 338
v=0
s=abs
t=0 0
a=sendrecv
a=ptime:20
a=maxptime:30
a=ptime:20
a=maxptime:30
a=fmtp:18 annexb=no
a=ptime:20
a=maxptime:40
SIP/2.0 100 Trying
Content-Length: 0
SIP/2.0 180 Ringing
Content-Length: 0
Max-Forwards: 70
Content-Length: 0
SIP/2.0 200 OK
Content-Length: 0
Content-Length: 0
CSeq: 168989904 ACK
Max-Forwards: 70
Content-Length: 0
Md Afzal Hossain
System Admin
Md Afzal Hossain
System Admin
it's ok with your config as per u need it
can you add sip trace when a call is made from MY pabx (where no E1 is involved)
i think the issue is on sdp : No P-Early-Media header received and My pbx is sending cancel to CUCM.
i have a cisco router with sip to oxe and when he send a 18X to oxe sdp is there
