SIP trunk DID problem
d_ivanov
Post by d_ivanov »
I have a very strange problem with OmniPCX Enterprise R12.3.1 m4.501.10.d. It is detected when I unsuccessfully try to make a call on a missed call on a sip phone 8008. and this problem is due to an incorrectly formed FROM field.
As I understand it should be:
From: "892818009" <sip:892818009@10.18.0.20;user=phone>
Can someone help me fix the situation? :shock:
Q931 Signal variant ISDN-all
I'll give you a trace below:
23:51:03.096381 IP (tos 0xa0, ttl 59, id 25455, offset 0, flags [none], proto UDP (17), length 862)
sip.bisv.kz.5060 > cs3.5060: SIP, length: 834
INVITE sip:5551356@158.58.132.67 SIP/2.0
Via: SIP/2.0/UDP 93.190.23.2:5060;branch=z9hG4bK2d01706d;rport
From: "892818009" <sip:892818009@93.190.23.2>;tag=as3d9e65b6
To: <sip:5551356@158.58.132.67>
Contact: <sip:892818009@93.190.23.2>
Call-ID: 02796a0768b119206bab62f31b618f67@93.190.23.2
CSeq: 102 INVITE
User-Agent: Asterisk PBX
Max-Forwards: 70
Date: Fri, 23 Aug 2024 20:51:03 GMT
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY
Supported: replaces
Content-Type: application/sdp
Content-Length: 284
v=0
o=root 4909 4909 IN IP4 93.190.23.2
s=session
c=IN IP4 93.190.23.2
t=0 0
m=audio 10510 RTP/AVP 8 0 18 101
a=rtpmap:8 PCMA/8000
a=rtpmap:0 PCMU/8000
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=ptime:20
a=sendrecv
23:51:03.097252 IP (tos 0xb8, ttl 64, id 25018, offset 0, flags [none], proto UDP (17), length 339)
cs3.5060 > sip.bisv.kz.5060: SIP, length: 311
SIP/2.0 100 Trying
CSeq: 102 INVITE
Via: SIP/2.0/UDP 93.190.23.2:5060;received=93.190.23.2;branch=z9hG4bK2d01706d;rport=5060
Content-Length: 0
23:51:03.101572 IP (tos 0xb8, ttl 64, id 55159, offset 0, flags [none], proto UDP (17), length 922)
cs3.5060 > 10.18.2.138.5060: SIP, length: 894
INVITE sip:210@10.18.2.138:5060;transport=udp SIP/2.0
Allow: INVITE, ACK, CANCEL, BYE, PRACK, NOTIFY, REFER, SUBSCRIBE, OPTIONS, UPDATE, INFO
Supported: replaces,timer,path
User-Agent: OmniPCX Enterprise R12.3.1 m4.501.10.d
Session-Expires: 1800;refresher=uac
Min-SE: 900
To: "IT Office" <sip:210@10.18.0.20;user=phone>
From: "892818009" <sip:10.18.0.20;user=phone>;tag=54141df46e87c8258f92d4988c5025a3
Contact: <sip:10.18.0.20;transport=UDP>
Call-ID: 2206cae10371c93f439b29c7d87051ba@10.18.0.20
CSeq: 51108496 INVITE
Via: SIP/2.0/UDP 10.18.0.20;branch=z9hG4bKf50468aea937f75416359adbc1cedcf6
Max-Forwards: 70
Content-Length: 215
v=0
o=OXE 1724446263 1724446263 IN IP4 10.18.0.20
s=abs
t=0 0
m=audio 10510 RTP/AVP 8 101
a=sendrecv
a=ptime:20
a=maxptime:30
23:51:03.102138 IP (tos 0xb8, ttl 64, id 25019, offset 0, flags [none], proto UDP (17), length 530)
cs3.5060 > sip.bisv.kz.5060: SIP, length: 502
SIP/2.0 180 Ringing
Allow: INVITE, ACK, CANCEL, BYE, PRACK, NOTIFY, SUBSCRIBE, OPTIONS, UPDATE
Contact: sip:10.18.0.20
To: <sip:5551356@158.58.132.67>;tag=e55b8c1ef8740f76a497a2c8694860b1
CSeq: 102 INVITE
Content-Length: 0
23:51:03.170103 IP (tos 0xa0, ttl 64, id 62666, offset 0, flags [none], proto UDP (17), length 631)
10.18.2.138.5060 > cs3.5060: SIP, length: 603
SIP/2.0 180 Ringing
To: "IT Office" <sip:210@10.18.0.20;user=phone>;tag=3541322697
Allow: ACK, BYE, CANCEL, INFO, INVITE, MESSAGE, NOTIFY, OPTIONS, REFER, SUBSCRIBE, UPDATE
Contact: <sip:210@10.18.2.138:5060;transport=udp>;expires=300
Server: Alcatel-Lucent ICTouch-Phone 8008
Supported: answermode, eventlist, replaces, sdp-anat, timer
Content-Length: 0
23:51:08.966578 IP (tos 0xa0, ttl 59, id 25456, offset 0, flags [none], proto UDP (17), length 377)
sip.bisv.kz.5060 > cs3.5060: SIP, length: 349
CANCEL sip:5551356@158.58.132.67 SIP/2.0
CSeq: 102 CANCEL
Max-Forwards: 70
Content-Length: 0
23:51:08.968772 IP (tos 0xb8, ttl 64, id 25020, offset 0, flags [none], proto UDP (17), length 417)
cs3.5060 > sip.bisv.kz.5060: SIP, length: 389
SIP/2.0 200 OK
Supported: timer,path,100rel
CSeq: 102 CANCEL
Content-Length: 0
23:51:08.969410 IP (tos 0xb8, ttl 64, id 55160, offset 0, flags [none], proto UDP (17), length 501)
cs3.5060 > 10.18.2.138.5060: SIP, length: 473
CANCEL sip:210@10.18.2.138:5060;transport=udp SIP/2.0
Supported: replaces,timer,path,100rel
CSeq: 51108496 CANCEL
Max-Forwards: 70
Content-Length: 0
23:51:08.969755 IP (tos 0xb8, ttl 64, id 25021, offset 0, flags [none], proto UDP (17), length 516)
cs3.5060 > sip.bisv.kz.5060: SIP, length: 488
SIP/2.0 487 Request Terminated
CSeq: 102 INVITE
Content-Length: 0
23:51:08.971604 IP (tos 0xa0, ttl 59, id 25457, offset 0, flags [none], proto UDP (17), length 450)
sip.bisv.kz.5060 > cs3.5060: SIP, length: 422
ACK sip:5551356@158.58.132.67 SIP/2.0
CSeq: 102 ACK
Max-Forwards: 70
Content-Length: 0
23:51:08.978916 IP (tos 0xa0, ttl 64, id 62667, offset 0, flags [none], proto UDP (17), length 411)
10.18.2.138.52753 > cs3.5060: SIP, length: 383
SIP/2.0 200 OK
Content-Length: 0
23:51:08.979842 IP (tos 0xa0, ttl 64, id 62668, offset 0, flags [none], proto UDP (17), length 579)
10.18.2.138.5060 > cs3.5060: SIP, length: 551
Content-Length: 0
23:51:08.980459 IP (tos 0xb8, ttl 64, id 55161, offset 0, flags [none], proto UDP (17), length 419)
cs3.5060 > 10.18.2.138.5060: SIP, length: 391
ACK sip:210@10.18.2.138:5060;transport=udp SIP/2.0
From: "892818009 " <sip:10.18.0.20;user=phone>;tag=54141df46e87c8258f92d4988c5025a3
CSeq: 51108496 ACK
Max-Forwards: 70
Content-Length: 0
Re: SIP trunk DID problem
can you break down the calls. same trace. use motor trace 2 for log level
seems like a domain not setup in your gateway maybe?
d_ivanov
Post by d_ivanov »
The above trace is one call from number 892818009 to number 5551356, after the call goes through DID 5551356 is converted to 210, at the moment of conversion from 5551356 to 210 in the FROM field the URI changes:
to
in attachment traced 2
d_ivanov
Post by d_ivanov »
when calling a missed call on phone 210, the IP address is substituted
From: 10.18.2.138 <sip:10.18.2.138@10.18.0.20>;tag=964875b4c7
To: "10.18.0.20" <sip:10.18.0.20@10.18.0.20>
What's your NPD like on this trunk?
d_ivanov
Post by d_ivanov »
I tried
Public NPD ID 3
Description identifier 3
Name U_U_E_E_DDI
Calling Numbering plan ident. Unknown
Called numbering plan ident. Unknown
Authorize personal calling num use False
Install. number source Entity source
Default number source Entity source
Called DID identifier 0
Calling/Connected DID identifier 0
and
Public NPD ID 10
Description identifier 10
Name IU_IU_E_E_DDI
Calling Numbering plan ident. NPI/TON: ISDN Unknown
Called numbering plan ident. NPI/TON: ISDN Unknown
Private NPD ID 0
Management Mode Automatic
Public DID transcoding - Tru
8008 in sip mode ?CHECK THE ACCOUNT setting
header issue
invite no conform
iNVITE
Mon Aug 26 19:41:31 2024 REQUEST URI : <> 5551356@158.58.132.67:5060 ; user=name
1724690491 -> Mon Aug 26 19:41:31 2024 FROM : <89281800> 89281800@93.190.23.2:5060 ; user=name
Mon Aug 26 19:41:31 2024 TO : <> 5551356@158.58.132.67:5060 ; user=name
89281800 is considerate as a name not a tel
invite in conformity
REQUEST URI : <> 077060@10.235.96.133:5060 ; user=phone
1724907286 -> FROM : <51009> 51009@10.235.96.130:5060 ; user=phone
1724907286 -> TO : <> 077060@10.235.96.133:5060 ; user=phone
even the contac fiel is wrong
From: "89281800" <sip:10.18.0.20;user=phone>;tag=503190a2a551065fdc03d4c013f70283
d_ivanov
Post by d_ivanov »
Good day haroun
8008 in sip mode
settings:
Directory Number
210
Directory name
IT
Directory First Name
Office
UTF-8 Directory Name
IT Office
UTF-8 Directory First Name
Location Node
1
Shelf Address
255
Board Address
255
Equipment Address
255
Set Type
SIP extension
Sub type
IPTouch 8008
Entity Number
1
Set Function
Default
Domain Identifier
0
Language ID
1
Secret Code
Multi-line station
YES
Can be Called/Dialed By Name
YES
Phone book Name (Dial by name)
IT
Phone book First Name
Office
Displayed Name
IT Office
do you think that the invite package from the provider contains user=name instead of user=phone?
hi😊
TEL URI
If the phone has an assigned PSTN telephone number, this field should be set to "User=Phone". Then a "User=Phone" parameter will be attached to the Request-Line and "TO" header in the SIP request to indicate the E.164 number. If set to "Enable", "Tel:" will be used instead of "SIP:" in the SIP request.
Some sip phones have the ability to gonfig the tel uri
yep i just tried to make some changein a sip phone tel uri look what i got he was unable to call
RECEIVE MESSAGE FROM NETWORK (10.235.96.136:5060 [UDP])
INVITE tel:51009 SIP/2.0
Via: SIP/2.0/UDP 10.235.96.136:5060;branch=z9hG4bK95831665;rport
Route: <sip:10.235.96.130:5060;lr>
From: "Salles Pompes lrb" <sip:553720@10.235.96.130;user=phone>;tag=1809968060
To: <tel:51009>
Call-ID: 525599149-5060-60@BA.CDF.JG.BDG
CSeq: 590 INVITE
Contact: "Salles Pompes lrb" <sip:553720@10.235.96.136:5060;user=phone>
Max-Forwards: 70
User-Agent: Grandstream GXP1615 1.0.4.55
P-Preferred-Identity: "Salles Pompes lrb" <sip:553720@10.235.96.130;user=phone>
P-Access-Network-Info: IEEE-EUI-48;eui-48-addr=AC-A0-16-AD-CA-75
P-Emergency-Info: IEEE-EUI-48;eui-48-addr=00-0B-82-BF-FD-B0
Supported: replaces, path, timer
Allow: INVITE, ACK, OPTIONS, CANCEL, BYE, SUBSCRIBE, NOTIFY, INFO, REFER, UPDATE, MESSAGE
Accept: application/sdp, application/dtmf-relay
Content-Length: 382
1725193743 -> SEND MESSAGE TO NETWORK (10.235.96.136:5060 [UDP]) (BUFF LEN = 292)
SIP/2.0 100 Trying
To: <tel:51009>
CSeq: 590 INVITE
Via: SIP/2.0/UDP 10.235.96.136:5060;received=10.235.96.136;branch=z9hG4bK95831665;rport=5060
Content-Length: 0
--endMessage (10.235.96.136:5060)
SIP/2.0 100 Trying
To: <tel:51009>
CSeq: 590 INVITE
Content-Length: 0
SIP/2.0 416 Unsupported URI Scheme
To: <tel:51009>
CSeq: 590 INVITE
Content-Length: 0
ACK tel:51009 SIP/2.0
To: <tel:51009>
CSeq: 590 ACK
Content-Length: 0
Return to “SIP”
