Grandstream SIP VoIP extensions not able to make or receive calls
imukonyezi
Post by imukonyezi »
Dear Community,
I have a R100.1 OXE system which has enough SIP extension licenses.
We recently purchased Grandstream SIP devices of type GRP 2602. The SIP extension registers on the system with the newly created SIP accounts.
However making and receiving calls is a problem. I have run two scenarios
1. Making calls between the new Grandstream and an existing NOE set
2. Making calls between the Grandstream and existing Alcatel SIP extension like 8001G and OmniTouch 4135
Below in the attachment text are the different scenarios and corresponding traces
alex
Re: Grandstream SIP VoIP extensions not able to make or receive calls
Post by alex »
Setup properly your Grandstream.
In 1st call trace you have this from your set.
SIP/2.0 480 Temporarily not available
Via: SIP/2.0/UDP 172.16.5.6;branch=z9hG4bK5179c53efaaab83f9af4ac0b6f34cfa7
From: "ISAAC MUKONYEZI" <sip:2650@172.16.5.6:5060;user=phone>;tag=a55795f70188f49c348b6c02e8f1ba3f
To: "SIP ISAAC MUKONYEZI" <sip:2991@172.16.5.6:5060;user=phone>;tag=1841203841
Call-ID: 37072295c7a9c8a8feafc370ed5a1c56@172.16.5.6
CSeq: 50343593 INVITE
Supported: replaces, path
User-Agent: Grandstream GRP2602P 1.0.3.72
Warning: 399 GS "Do-not-disturb is on"
Allow: INVITE, ACK, OPTIONS, CANCEL, BYE, SUBSCRIBE, NOTIFY, INFO, REFER, UPDATE, MESSAGE
Content-Length: 0
In 2nd call - there is a BYE coming from Grandstream right after answer from NOE.
Wed Sep 11 17:16:37 2024 RECEIVE MESSAGE FROM NETWORK (172.16.5.21:15906 [UDP])
BYE sip:172.16.5.6:5060 SIP/2.0
Via: SIP/2.0/UDP 172.16.5.21:15906;branch=z9hG4bK134845491;rport
To: <sip:2650@172.16.5.6>;tag=5098aadfac9d0a86899029dc239bdaef
Call-ID: 1149125845-15906-48@BHC.BG.F.CB
CSeq: 471 BYE
for the second part u have codecs mismatching( 488 and media rejected)
did you managed the compression type for system?
try to decrease the number of the offered codecs in sdp like g711a and g729 only; or manage domain for sets with the adequate compression intra/extra and
imukonyezi
Dear Alex and haroun,
Thank you for the feedback and support.
I managed to only get the grandstream set working with both noe and sip extensions after I created the user as sip device and not sip extension.
I have always wondered...what is the technical difference between sip device and sip extension users?
hi
for sip extension the set is considered as whole part of the system and sip device is considered as remote network and need sip trunk and gateway
for sip extension
try this system parameters it's under system /go down in hierarc/qOther System Param /go down in hierarc/Compression Parameters
Compression Parametersqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqk
x x
x Instance (reserved) : 1 x
x System Option + Compression Type x
x x
x Compression Type + G 729 x
x
i have some Grandstream GXP1615 and GXV3240 are working perfectly as sip exten with this codec list
Send DTMF in-audiovia RTP (RFC2833)
DTMF Payload Type 101
Preferred Vocoder - choice 1 G.729A/B
Preferred Vocoder - choice 2 PCMA
Zelinuppy
Post by Zelinuppy »
I did this before by manually building 3 SUs with clear separation and linking each to a set of users using COR. That way, each group worked independently without issues.
Return to “SIP Extension”
