Deleting media gateway from omnivista
Mr_41Magnum
Post by Mr_41Magnum »
Hi everybody,
yesterday I shut down one of our media gateways. Now I want to remove it from OXE.
As I can see it, I only have to delete it from the omnivista tree - see screenshot.
Or is there anything else to consider?
73!
Tom
Re: Deleting media gateway from omnivista
Delete user and trunk from boards. Delete boards. Only after this - you can remove shelf.
Mr_41Magnum
Thanks, the boards are removed, but I can't remove the GD3
sorry for German, meaning "invalid operation"
Anything to prepare before removing the GD3?
If all board (except GD) removed - try to delete shelf.
