alcatel ip desktop cleint for linux or similar
flavioperaca
Post by flavioperaca »
I would like to know if there is a .deb or any other version for Linux of Alcatel IP Desktop Softphone. I know there are some Linux alternatives, but I don't know which one is the best... I am currently trying to configure Jami, but I am still missing some information on the server side.
Is there a Linux or Windows command that I can use to find out these settings? Where can I find them?
Re: alcatel ip desktop cleint for linux or similar
ZoIPER, CounterPath X-Lite.
GerardoAragon
Post by GerardoAragon »
For Linux, there’s no official Alcatel IP Desktop client. You can use alternatives like Jami, Linphone, or Zoiper, and check server settings via SIP account details or network traces.
Return to “System”
