Alcatel os6450-u245 2 switch stack
Sierra83
Post by Sierra83 »
Our primary switch failed and now the secondary is primary but with slotnumber 2.
Can the primary switch run slotnumber 2, or should we change the slotnumber to 1?
Re: Alcatel os6450-u245 2 switch stack
There is no problem with this. Any slot can be the primary.
If you whish the #1 as primare again you can reboot the whool stack or do a "takeover" command.
BR Silvio
Return to “OmniSwitch 6450”
