VLAN-leak with a cable
MartK
Post by MartK »
Hello forum,
Is it possible to leak a VLAN to another VLAN with a cable within the same switch? OS6560-48X4
We have two VLAN in the switch. VLAN 100+200
A DHCP-service is running on VLAN 100. We want to leak VLAN 100 to VLAN 200 but be able to disconnect it with a cable.
Right now VLAN 100 is untagged on 1/1/10. VLAN 200 is untagged on 1/1/20.
The DHCP-server is connected on 1/1/1 with VLAN 100 tagged.
If we connect 1/1/10 (100u) to 1/1/20 (200u) both VLANs on their respective port get status blocked. I guess the switch doesn't like that.
The ports are still up and there are no violations.
Re: VLAN-leak with a cable
This is the correct way - both ports untagged in different vlan.
The blocking is because of spanning tree. You need to disable this.
For stp in flat mode you use the command
spantree cist port 1/1/10 disable
spantree cist port 1/1/20 disable
For stp in perVlan mode:
spantree vlan 100 port 1/1/10 disable
spantree vlan 200 port 1/1/20 disable
Loopback-detection needs also to be disabled at this ports (this is the default).
BR Silvio
