Notification destination Printer Not Ok
Hi guys ! any help Gurus
getting a headash to make it work
scneario:
otfc r9.1 and win2019 serv as OS
direct routing table managed to a printer
printing test page is ok but printing the faxes is KO ,
Getting this error in the smpt log
Executing print command : Executable does not exist
1)(2024/12/16 11:35:23.963)(1e1c)(RouteJobPoller::ProcessRouteJob ): Processing routing job : jobid=DA0D61DC-B3EF-4B5A-B72724121D968E95-1186-FN desttype=Printer destname=FAX
(1)(2024/12/16 11:35:23.977)(1e1c)(DefaultPrinterNotification ): Executing print command : Executable does not exist
(2)(2024/12/16 11:35:23.978)(1e1c)(RouteJobToPrinter::Submit ): Executing print command : Executable does not exist
(1)(2024/12/16 11:35:23.978)(1e1c)(RouteJobPoller::ConfirmRoutingStatus ): Confirming route job status to fax manager...
(1)(2024/12/16 11:35:23.978)(1e1c)(RouteJobPoller::ConfirmRoutingStatus ): Status to confirm : jobid=DA0D61DC-B3EF-4B5A-B727-24121D968E95-1186-FN desttype=Printer destname=FAX completioncode=71002 state=transient error ocrpages=0
(1)(2024/12/16 11:35:25.006)(1e1c)(RouteJobPoller::ConfirmRoutingStatus ): Confirming route job status to fax manager...done
(1)(2024/12/16 11:35:25.006)(1e1c)(RouteJobPoller::ProcessRouteJob ): \--PROCESSING ROUTE JOB... DONE
Re: Notification destination Printer Not Ok
Look for the path for the "print" command in ms dos SHELL.
If not in the path, add it through the local variables.
Return to “OTFC - OpenTouch Fax Center”
