Change default VLAN 1 to 100
andit
Post by andit »
I have a small Problem. We are connecting two different company’s together.
They are 100m away so its no Problem. LWL is working fine.
But on one site there is the VLAN1 used for Intern Traffic now i must change our configuration (5 Switch)
I have a script where i add all VLANS and assign the Ports to VLAN 100 (new management-Switching) but wehen i want use it on the SFP Ports i get a error „mobile….“ but with GUI its works
Now is my question is it possible to change the default VLAN id from 1 to 100!!!
Thanks for the help.
get this error: ERROR: Port is not mobile and must be for this command
Regards Andi
Re: Change default VLAN 1 to 100
Which commands to you use in your script?
The command to change the default vlan is to configure a new one.
vlan 100 port default 1/24
BR Silvio
Return to “OmniSwitch 6450”
