Hi all,
Anyone has experience with the 6900 and can confirm that it can handle Bonjour protocol (airplay / AirPrint) ?
Thank you
Can the OmniSwitch 6900 handle Bonjour protocol?
- frank
Re: Can the OmniSwitch 6900 handle Bonjour protocol?
Hi Frank,
yes - all switches can it. This protocols are using mDNS (so this is multicast). Within the same vlan you can leave the default - multicast will flooded at all ports within the same vlan. But this is not my recommendation. If you would like to handle multicast like multicast we have to activate it (and need a querier). See a lot of my other posts
For mDNS and ssdp (used for upnp) between differnet vlans use the following commands:
Best regards
zeroconf mode gateway
zeroconf mdns admin-state enable
zeroconf ssdp admin-state enable
zeroconf gateway-vlan-list 1 10 11Silvio
