Upgrade path
stich86
Upgrade path
Post by stich86 »
Hello guys,
still back on this nightmare :)
I’ve about 10 6560, most of them are at 8.6.299R01, just two are at
8.9.107.R02
All of them are not under support… is it possible to copy the image from one updated and move it to the other one? I’ve seen that for these switch U-Boot and FPGA needs to be updated, are 8.6 compatible with 8.9?
Thanks in advance
Cristek
Re: Upgrade path
Post by Cristek »
I believe the release notes for each version list the minimum requirements, from there you'll know if you need to upgrade them or not.
As for the image copy, I suppose you can FTP from one switch to another and copy the file, but I always do it with a USB flash drive if I'm locally connected or via WinSCP if remotely connected.
stich86
Re: Upgrade path
Post by stich86 »
I've seen that 8.9.107R02 needs at minium Uboot\FPGA
FPGA version : 0.4
U-Boot Version : 8.5.265.R02
That's all my switch have (except the upgraded one to 8.9, that are running FPGA version: 0.8 - U-Boot Version: 8.9.85.R02)
So if I copy Nos.img from an update one, to another should it work?
@silvio any suggestion?
Thanks!
Re: Upgrade path
Yes, this is possible. You can copy the img-files between the switches f.e. with scp.
For fpga and uboot this is also possible - if you find the correct files in the /flash (normaly you can delete this files after the upgrade command).
You need the files like fpga_kit_8405 and OS6560_u-boot.8.9.R02.85.tar.gz (or other numbers).
BR Silvio
stich86
Re: Upgrade path
Post by stich86 »
What’s the correct order to upgrade?
Copy the Nos.img in which folder? How to mantain older image?
Cristek
Re: Upgrade path
Post by Cristek »
The latest release notes have all the procedures ready for you in appendix E and G/H (and I recommend you take a read of D as well)
Hope this helps!
