How to add multiple IPs to Loopback interface?
zlinuxboy
Post by zlinuxboy »
I want to simulate subnets connect to the device without real physical devices connection. The other vendor permit user to assign multiple IPs to loopback for that. but ale aos8 doesn't work, Any alternative way to do that on aos8?
Re: How to add multiple IPs to Loopback interface?
If you have at least one active port at the switch (maybe a hairpin cable or one of your used ports) than you can tag there a lot of vlans (without tagging at the other end). And every vlan with its own ip ....
BR Silvio
zlinuxboy
Post by zlinuxboy »
brillian!
Return to “OmniSwitch 6900”
