Hi Gurus,
A client wants to have/develop a real time monitoring dashboard for OXE.
The dashboard needs to have;
1. Current number of users / extensions in communication. Refresh in realtime once a call gets connected / disconnected
2. Current number of trunks/circuits in used /available . Refresh in realtime once a call gets connected / disconnected
3. Current number of compressors in used / available. Refresh in realtime once a call gets connected / disconnected
4. History of the above counts. (previous hour, day, etc)
5. Realtime call logs.
6. Call log history.
7. Charts / graph, etc
Do we have such application for OXE?
Commands I can think of which can fetch raw current data; listincall, listerm, trkstat, compvisu, etc. But this means to execute these command in the terminal.
Any inputs will be highly appreciated.
Realtime OXE monitoring.
Re: Realtime OXE monitoring.
Never heard about such an application, would be great to have one. But it would take a lot of time and resources to create this kind of app.
For 1-2 you could use CSTA - no problem. You will get all events from monitired equipment in real-time. For that you need CSTA licenses in OXE and 3rd party SW.
3 - not sure whether CSTA in OXE supports monitoring codecs.
4 - you have PastTime Perfomance in 8770 Omnivista with counters for subscribers, trunks, DECT BS's etc. But wthat you need for that? Correct - Licenses! Or you could read pmm files from OXE and decode them.
5 - At least it's free of charge (but for local calls CDRS you need license). Real-Time Acoounting protocol is pretty simple and easy to implement. Check, e.g., here https://www.alcatelunleashed.com/viewforum.php?f=475
6 - Its from point 5 - when you have CDRs you could process them the way you like
7 - As soon as you have data you could use whatever you want to build charts, dashboards etc. ELK stack is a good way to do it. Also Grafana etc.
You could use some CLI commands but it wont be exact Real-Time observation and as you need to run these commands at the same time it could cause some problems with the CPU load.
Thanks you for the great info alex - one of the pioneer guru here.
i wonder where are the rest, vad ? cav ? frank ? still doing alcatel stuffs...
For some system resources, trunks, ... You can also use snmp
Yep, good point about SNMP.
But SNMP implementation has, FMPOV, some restrictions - it's dependent on SW Release of OXE and it gives global view on PABX's resources status.
SNMP is the way to go. Look through the OID/MIBS
We are using it for SIP trunk monitoring. Dont know about set info ect., but it might be there
