After upgrade incvisu reports ...
tomekandos
Post by tomekandos »
After upgrading my OXE incvisu reports:
I split incidents into sections for easier reading:
03/04/25 06:01:15 000001S|---/--/-/---|=0:2663=IPC Chorus err: appli MAO_AGENT oper 18 err 11
03/04/25 06:01:15 000001S|---/--/-/---|=0:2663=IPC Chorus err: appli MAO_AGENT oper 30 err -1
03/04/25 17:08:52 000001M|020/02/-/---|=4:5400=4645 Software Error: Error Code 0x 0.16 Module 0x 0. 0 Line 0x 0.59
03/04/25 18:19:34 000001S|---/--/-/---|=2:2650=SQL error: appli CMISE table No 2650 error -26003
03/04/25 19:22:31 000001M|---/--/-/---|=2:2251=A16: Pb ipcReceive with 16, st = 679 (?)
Using incinfo I can't find satisfying explanations.
Maybe you can help and tell which of these incidents can be important or need fast intervention or what consequences I can expect?
Best regards.
Return to “ON SITE TROUBLES”
