Bulk editing users
This application replaces the OmniVista 4760
Thomas_AP
Bulk editing users
Post by Thomas_AP »
We are currently using OmniVista8770 to managed our VoIP telephony but we are in the process of switching to another system. We are now in some kind of hybrid stage where some user are still managed in OmniVista and others are already migrated.
Therefor we need to forward internal calls, to migrated user, externally so calls are routed by the SBC to the new system.
We'd like to continue working in waves of 100+ users at the same time.
What I did thus far is, for each migrated user, change the Forward tot Immediate forward and Forward Directory Number from the internal extension to the external number (e.g.: 6789 to 0012346789, appending "001234" each time).
This was quite intensive manual work.
My knowledge of OmniVista is pretty basic and I suppose and hope there is an easier way to do this.
My main question is: Can this be simplified or automated? Would you take another approach?
Specifically I was wondering if there was a way to script this starting from an csv-file?
Or to export the config, edit it (manually or automatically) en import it back with the changes?
Thanks in advance
Re: Bulk editing users
If you move users by range - f.e. users 67XX moved to external system:
- delete users 67XX
- create Speed dial (abbreviated number) - speed dial no prefix 67, call number 00123467
Thomas_AP
Post by Thomas_AP »
Thanks! I will look into this solution.
Unfortunately we are not moving users by range but by their department in our organization. There is no big range (numbers in a consecutive order) that we can migrate. If there was a way to start from a excel file that would be great.
Return to “OmniVista 8770”
