help file /working deleted
admin_ngaso
Post by admin_ngaso »
help! yesterday im type command rm working and restart
and typing copy certified working make-running-directory not worked at typing write memory flash-synchro as same not worked
in this file inside /working deleted
nos.img
cspbroker.md5
boot.md5
naasclient.cfg
cloudagent.cfg
software.lsm
vcsetup.cfg
vcboot.cfg
devices: OS6860N-P24Z
Cristek
Re: help file /working deleted
Post by Cristek »
since you deleted the working folder, all you can do (if you dont have a backup to manually upload) is 'copy certified working'
and then, if the config you are currently running is different than the one in certified (the one you also just copied to working) then you can overwrite it and save it properly again.
