Clip no sreening with oxo -> Alternative CLIP
Harald
Post by Harald »
in instalation Numbers i fill the Alternative CLIP with 9596 , my installation number is 2234848 intercity is 5321.On outgoing Call the number i will send is 053212239596291 (user is 291). The right number must 053219596291 . When i fill the instalatin number with 9596 i send 053219596291 but the incomming call is not possible. Has anyone an Idea . The Release is 5.0.
mozi
Re: Clip no sreening with oxo -> Alternative CLIP
Post by mozi »
You have to use the DDI Number Modification Table.
Just remove in the Installation NUmber Window the Installation NUmber and the Alternative Clip Entry.
Then Add them in the DDI Number Modification Table like this:
Index External DDI Internal DDI
1 2234848 1
2 9596 2
then change in the Public NumberingPlans the Entries:
Start End Base
200 299 200
to
Start End Base
1200 1299 200
2200 2299 200
Now if add in the Subscriber/Details/Misc the Field Alternativ Clip/Colp you shoud get the wanted result
Example user 291 add 2291
elias_ruiz_diaz
Post by elias_ruiz_diaz »
mozi wrote:You have to use the DDI Number Modification Table.
1 2234848 1
2 9596 2
Start End Base
200 299 200
to
Start End Base
1200 1299 200
2200 2299 200
I have a question respect to this, sorry about my ignorance.. If my number of T2 is 688-6000, and i have an extension 6711, and i make an outgoing call, the call receiver will see the number "688-6711" if i do the configuration you explained? Or that's not the use for CLIP/COLP number?
Return to “ON SITE TROUBLES”
