TCP/IP Flow matrix
jmjacques
TCP/IP Flow matrix
Post by jmjacques »
We are trying to identify the IP desktop softphone really used (not only set up).
Considering it is not possible to get this information from the OXE/AS nor 8770, we will try to get that from a network trace analysis.
Could someone give us the TCP/IP Flow matrix ?
alex
Re: TCP/IP Flow matrix
Post by alex »
Hmm not sure that ip flow will help you to identify such sets
A tool to check counters on the set (converstaion counter is one of them) is dbgobs https://www.alcatelunleashed.com/viewtopic.php?t=3256
Return to “Ip Desktop Softphone”
