Need a help plz....we have 8058s model IP phone. I just want to program Multiple extensions on guest IP phones with same Pattern. we already configured keys but management want to change the old configured keys....we almost have 387 IP phones its not possible to configure keys manually on all sets....is it possible to define 1 key that synchronize on all phone sets?????
configuration of speed dial
- frank
Re: configuration of speed dial
You can setup a set profile, or you can use the OmniVista 8770 to multi-edit all your IP Phones at the same time.
Using Omni Vista 8770 but don't have deep knowledge about system configuration.....can you plz describe the steps or any documentation for help????
- frank
Documentation will tell you how to do it. It's available in this board.
