CS-3 upgrade
mtcl
CS-3 upgrade
Post by mtcl »
Hello
We need to upgrade a CS-3 from n3.510-6 to n3.510-7 (just the dynamic patch). Is there a process to upload the dynamic files to a specific directory of the CS-3 and upload from this path or it is mandatory to use SOT ?
Re: CS-3 upgrade
Either though FTP in swinst, or through /tmpd/xx.iso in auto load in swinst
mtcl
Re: CS-3 upgrade
Post by mtcl »
Thanks Frank
Any document from ALU about this process ?
Re: CS-3 upgrade
It's really poor.
Update ISO in /tmpd folder, then swinst , option 2 , 9 , 10 , and enter the iso file.
New install will be loaded on 2ndary partition. You'll need to copy network settings over from swinst. Then you can reboot and try.
Return to “GENERAL”
