Omnivista Captive Portal
maxmania
Post by maxmania »
I have the following setup
(PC) ==== (OS6450) === (Omnivista2500)
I have setup 802.1x with CP, but I only can access to the switch CP.
How can I use the OV CP in stand to authenticate ? Or the AOS6 do not support it?
Best regards
Jose
Best Regards
Jose Alves
Re: Omnivista Captive Portal
Hi, in your other post you write that CP with OV is working. I assume with R8 switches. The commands for R6 are different. You can find out it if you do the config via OV. For beginners you should use Unified Access > Unified Profile > Workflow with CP. Do it at a test switch....
BR Silvio
