os 6900 : bcmd esm ERR
aurik
Post by aurik »
Hello.
I have a new error on my core switch : Alcatel-Lucent Enterprise OS6900-X48C4E 8.10.102.R01 GA, July 14, 2024.
This error appears constantly and I don't understand what it means.
Fri Oct 10 13:28:35 : bcmd esm ERR message:
+++ phy_82391_link_get:ERR: u=0 p=25 failed to get link status
Fri Oct 10 13:28:36 : bcmd esm ERR message:
Fri Oct 10 13:28:37 : bcmd esm ERR message:
Fri Oct 10 13:28:47 : bcmd esm ERR message:
Fri Oct 10 13:28:48 : bcmd esm ERR message:
Fri Oct 10 13:28:58 : bcmd esm ERR message:
It's a stack of two switches.
I checked the status of interfaces 1/1/25 and 2/1/25, and I don't have any CRC errors or anything else.
I don't have any existing linkagg 25.
I'm completely stumped.
Thank you in advance for your help.
Re: os 6900 : bcmd esm ERR
I am not sure about the error (actually I have no access to myportal). If possible than search there in the KB for this message.
BCM is in my knowledge Broadcom error message. This menas deeper in hardware.
I think u=0, p=25 means 1/1/24 or 2/1/24... so check the show interface commands for this ports too.
You have to decide the next steps - espacelly if you don't see any issue.
You can check in the log when this message has started. Sometimes you find than the reason.
If possible you can do an restart of the VC .... Maybe together with an update to the actual release.
BR Silvio
aurik
Post by aurik »
1/1/24 ? not 25 ?
I will schedule a reboot and see !
I assume that the count is starting here with 0: u=0 means than slot/unit 1 and p=25 means port 26 (my mistake, not 24 and not 25). Hope you have active port 1/1/26.
Return to “OmniSwitch 6900”
