O2G & ALE softphone: outgoing call not dialled (softphone just rings / Busy state)
smallf00t
Post by smallf00t »
Hi everyone,
I’m using O2G to control all my physical phones: make calls, answer, hold, transfer, etc. For the physical sets everything works perfectly.
For the softphone ALE Softphone 4.0.06 , almost everything works too (answering, holding, transferring…), except dialing a number.
When I ask O2G to place a call using the softphone, the softphone itself just starts ringing locally:
the app goes from foreground to background / disappears,
my status changes to “Busy”,
but the number is never actually dialled and the call is not set up. I need to place a dropme to free it.
I remember that, on the physical sets (UA), we had to configure a programmable key (headset key or similar) to avoid having to validate the call directly on the set.
My questions:
Is there an equivalent setting for the softphone so that O2G can directly place the call without this “local ringing” step?
Do I need to configure a specific programmable key / off-hook / auto-answer option for the softphone?
Is there any known parameter on O2G or on the PBX side that controls this behavior?
Thanks in advance for any hints or configuration examples!
Return to “O2G”
