show lldp remote-system - No Information
andit
Post by andit »
I have 10+ OS6450 (10Port - 48Port) Switch.
Since a few days I get no LLDP Information.
There are three HP 2920 there I get the Information.
For example: 0815-SW-01
Show lldp remote-system
Port 1/52 gave mit the information HP-2920-xxxx
Port 1/51: no Information - on this Port is a OS6450-P48
Enable LLDP with the command.
Configure
LLDP RUN
Didńt work. - Wrong Command
Thanks for Help Regards
Re: show lldp remote-system - No Information
you can check the lldp config at the ports (rx+tx) with show lldp config.
Show lldp 1/51 statistics - maybe some errors?
If you have any changes and can't find the reason: reload of the switch
BR Silvio
andit
Post by andit »
Hy thanks,
I have already reload the switch. nothing have changed.
will try it.
How can i enable LLDP an Ports.
Command
Config
Lldp run
—> wrong command
per default it is enabled. You check with "show lldp config" (Rx + Tx)
Enable it at all ports with "lldp chassis lldpdu tx-and-rx"
BR Silvio
Return to “OmniSwitch 6450”
