DECT 8232 TIME/DATE (GAP)
Lan
Post by Lan »
I am using an Alcatel DECT 8232 handset registered to a FRITZ!Box as a GAP handset (it is not connected to the original Alcatel base station, only directly to the FRITZ!Box).
The problem is that the time and date on the handset are not set correctly, and I cannot find any option to change them manually on the phone. Because it is used as a GAP device, some menu options seem to be missing.
Is there a way to set or sync the time and date when using an Alcatel DECT 8232 with a FRITZ!Box?
Thanks in advance for any help.
Return to “PWT/DECT System”
