board GD2 or GA2
LETACLA17
board GD2 or GA2
Post by LETACLA17 »
Hello
the board GD2 or ga2 are compatible with release F5 .401.14 (R7.1)???
It's necessary to flashing and charg new binary???
it's different of a classic GD or GA for charg binary????
Ihthisham
Re: board GD2 or GA2
Post by Ihthisham »
Is it a information or question?
LETACLA17
Post by LETACLA17 »
Ihthisham wrote:Is it a information or question?
IT'S A QUESTION
THANK
First of all, CAPLOCKS down ok?
Using capital letters means you are yelling. So be nice.
We are people so if you are in bad mood take it to another place.
:shock: Did I say that? :lol:
LETACLA17
Post by LETACLA17 »
cavagnaro wrote:First of all, CAPLOCKS down ok?
my question it's not clear???
board to ipbx OXE (gd2 and ga2)
thank :lol:
knightr1der
Post by knightr1der »
thank :lol:
With all the ???????? you put in the original post - It was clearly questions!
Maybe Ihthisham did not see the ?????? (question) marks :shock:
Ihthisham
Post by Ihthisham »
Ok Ok Knight, I did see ?????? so I confused with ? :lol:
There is a story. Sir Albert Einstine made a shell to his dogs. He had two dogs one was very small and other dog was big. He made two doors for the same shell one was small and other one was big. He didnt realize that the big door is enough for the small dog as well.
You know sometimes it happens :?
Coming to the questions........
It should ( I dont see this board mention on system limits doc until R 8.0, but Im quite sure it should work)
If binary is not available then u have to load it
Functionality should something more than GD/GA
Simply upgrade to the latest 7.1 software available on ABPS (static patch should do the job) and you will be sure that there are no problems :D .
About the flashing: the system will do the job.
Regards.
See TC0904-ed4 in TC forum.
Abismail
Post by Abismail »
Hi vad,
i have a same problem, I have not found the TC0904-ed4,
thank you;
Return to “GENERAL”
