demi_com command
alex
demi_com command
Post by alex »
I am not sure whether it is very usefull.Anyway I mentioned it.
Usage : demi_com <n neqt-number (0-2836)>
demi_com <d directory-number [1..8]>
demi_com <p crist-nb cpl-nb acces|us-nb term-nb>
demi_com <p crist-nb cpl-nb acces|us-nb a for all
Shows context of half-communication (demi-com in French) - software gadget assigned to ANY communication attempt.
Output of command shows all datum concerning the state at the moment.
On idle extension you will see nothing.In other states of call you will get a lot of information.Usefull info you
When user finished dialling using filter with "grep" you will see
a4400a>demi_com d 3000 | grep numcomp
numcomp = 3 4 7 0 1 9 6 0 _ _ _ _ _ _ _
numcomp = ^ idx_remp=8
numcomp = ^ idx_emis=4
numcomp = ^ idx_fin=8
Digits dialled by user - numcomp , length of number dialled -idx_remp=8,
digit from which PABX send dialling to trunk - ^ idx_emis=4, in this case - 347 - is a prefix was @consumed" by PABX and rest of it 01960 - was send on a trunk.
Return to “Usefull commands”
