Omnivista 4760 r420602 error during instalation
Shadow
Post by Shadow »
Hello
At the 42/77 step during instalation of Omnivista 4760 i receive one error about sql interactive :
error at line 1
Syntax error near "123456789" on line 1
GRANT CONNECT TO DBA INDENTIFIED BY 123456789
123456789 is my directory manager account password created in the steps before starting the instalation.
On the error window are 3 buttons:
Continue
Stop
Exit
If i click Continue, the instalation wizard starts a rollback action and after that a cannot reinstall Omnivista because i reiceive error about the omnivista_install.log file.
Full log file: D:\DOCUME~1\Catalin\LOCALS~1\Temp\OmniVista4760_install.log
Its drive me crazy
Please if you have any ideea about this i hope you can help me
Thank`s
Re: Omnivista 4760 r420602 error during instalation
Did you use to have ANYTHING on this PC ?
Just for the heck of it, can you reinstall the operating software, with *NO* complementary software.
This means no anti virus, remote stuff...
Also, note that not ALL Windows Service Pack are compatibles.
Once this is done, try to install again. It should go smoothless.
Please read the doc.
Return to “OmniVista 4760”
