Bell port in 4018
Rocco_DUP
Bell port in 4018
Post by Rocco_DUP »
Does anyone knows the function of the RJ45 port with a picture of a bell at the bottom of the Alcatel 4018 phone? Its function is to connect a headset or an external loudspeaker?
Re: Bell port in 4018
External ringing module
StfKdG
Post by StfKdG »
Hey,
Can someone tell me the part number of the external ringing module?
Thx!
henk1964
Post by henk1964 »
Think this is the one: 3GV28050AA
Module relaying the ringing signal towards an external device for Alcatel-
Lucent IP Touch and Digital phones‚ compatible with Reflexes™ range‚ with
RJ11/RJ11 3m cable‚ without power supply
Henk
StfKdG
Post by StfKdG »
Thanks!!!
murraya
Post by murraya »
Here's some info on the bell port. I think it's okay to post here as it is equipment for sale. I also will attach a circuit I made a few years ago that uses it. I guess Cav or Knigh will remove if need be.
cav:Yup, no attachs from Alcatel by the moment.
Best Regards
Murray
ACSE 10.0 corporate
ACSE 6.x IPT data
murraya
Post by murraya »
I thought it may have been an issue Cav, But what about the circuit I designed a few years ago. this was by pulling a phone apart before doc's were at hand. I guess it's not copyrighted as I never applied for one :D
I will wait for the go ahead before I post as I don't want to upset anyone :D :D :D :D :D
Best Regards
Murray
ACSE 10.0 corporate
ACSE 6.x IPT data
If you made the doc without extracting any pages or images from Alcatel documentation we are cool.
murraya
Post by murraya »
Here it is. Please note that I have never got around to doing a final fix for the issue of false triggering if you touch the circuit board. This is not really an issue if you put the finished circuit into a box of some sort.
Best Regards
Murray
ACSE 10.0 corporate
ACSE 6.x IPT data
Nice :)
Return to “IpTouch Phones XML Applications”
