MGR's menu modified.... Is it possible????
agiftel
Hi, I would lie to know if it's possible create an account ( different then mtcl ) which who connect by it can access to a MGR's menu restricted. I mean, for istance, that user can only see USERS, ABBREVIATED NUMBERS, GROUPS.
Is it possible??? I know with 4760 u can do it... but I am interested to make the same with MGR's menu..
Can someone Help me???
Thanks...
Thanks...
agiftel
Re: MGR's menu modified.... Is it possible????
Mmmmm maybe I didn't explain well what I wanna say.
I would like also create, after a new user login, a mgr menu like mtcl's one but with just some choice...like Users and Abbrevieted number...
Is it possible do that???
As I told in the first mes. i know that with 4760 u can create new users and for each of them u can create a special menu, when they will access to Configuration tool...
Is it possible????
Is it possible????
Oh yes, on the mgr menus check facilities level.
agiftel
Thank u...tomorrow I will try..
I 'll keep u informed beacause I tired something with that facilities one time ago...but I coould not understand how...
I will try again anyway..
See ya
See ya
Eliott_DUP
>mgr's menu modified.... Is it possible????
Yes, but it's not much customizable.
Eliott_DUP
You can create other user accounts and you can set access levels.agiftel wrote:What's u mean????
But you can not decide which flag is available for each single flag.
Restore login "client" via swinst and check in database management level what you see with this login enough for you or not.
agiftel
where can i see the client's level?????
Tx
Tx
