This will allow you to make changes to the voicemail without having to dial into the RMA board, or without having to be in front of the RMA board.
All you have to do, is telnet in the PBX, then use minicom !
Documentation wrote by Krusty65
Managing the 4635 through telnet
- frank
marius30
Re: Managing the 4635 through telnet
Hello Frank,
I am a beginner on this 4635/vpu5, and right now I try to have access on this card, if you are kind to help me.
What means WM1 ?.
- I start to build a cable from Alcatel jack (3x7 row) to Rj45. But I am not sure where I have to connect this on VPU5 back card?
- Can I buil a v24 cable just with black db25 but directly with male db25 ( I do not have M to M gender changer). The question it is ..where I have to connect on CBRMA this cable?
Many thanks
What means WM1 ?.
Many thanks
marius30
Hello
I build a cable v24 with db25 male , I connected on com D ( CBRMA) and start with pin 17 on VPU5 back card.
I setup until this step ' minicom –s ', the answer was : I da not have setup a minicom you need a admin to do that.
Some help can be possible , please.
Many thanks
Many thanks
- tot3nkopf
Were you in a root session like mentioned in the document? And that is on the OXE?
Root? I can't login as root, on login it doesn't allow me...heeelppp
- tot3nkopf
Let us put our sarcasm offcavagnaro wrote:Root? I can't login as root, on login it doesn't allow me...heeelppp
Yeah tot but... If we do a little search on forum would found the answer already. Have you seen his posts? I do understand a rookie trying to learn but not one who wants you to chew food for him as well...that is no begginer my friend. And sorry marius if I sound hard but if you searched you would be a step forward in solving your problem already.
Answer is do a su command as mtcl already logged in...
- tot3nkopf
Agree with thatcavagnaro wrote:Yeah tot but... If we do a little search on forum would found the answer already. Have you seen his posts? I do understand a rookie trying to learn but not one who wants you to chew food for him as well...that is no begginer my friend. And sorry marius if I sound hard but if you searched you would be a step forward in solving your problem already.
From the name I think me and him share the same nationality, so I am a little protective here
