half-com / demi-com
was this a dumb question?
Poll ended at 06 Oct 2005 10:52
yes
1
33%
no
2
67%
Total votes: 3
IceMan_DUP
half-com / demi-com
Post by IceMan_DUP »
Hi guys,
Where can I change the value of half-com links? And what should this value be? (....times users?)
Thanks,
IceMan
You can change this parameters with "cfgUpdate" command or directly in file hardware.mao (PARA_MAO 4). But best solution - use Actis, this software calculate this parameters depends of number of trunks, users, trafic and so on.
IceMan_DUP
Thanks Vad,
I knew it was something like that.
For all others who would like to know..
Go to the usr3 directory ->cd mao ->cfgUpdate ->option 11.
Return to “GENERAL”
