Easter eggs? Funny stuff...
alex
Post by alex »
Just been doing some explorations on OXE 6.1.
Found a kinda funny thing.
You can try it on yours OXE and say what you see
Just put in any browser
[url]https://<Your_OXE_address>/wtool/html/tools.html[/url]
and see what you get :D
alex
Post by alex »
Some news.
If in previuos post you can use "mtcl" account then on following page I did not succeed to log on using all possible existing accounts - mtcl, root, swinst, adfexc.
[url]https://<YourOXEaddress>/webtools2/php[/url]
Any ideas?
Nice trick... I will try to hack it later tonight and give you answer or a bypass :-)
alex
Post by alex »
frank wrote:Nice trick... I will try to hack it later tonight and give you answer or a bypass :-)
OK.Basically accounts and passwords as I understand initialised in a file "SecurityManagerTestProgram.php"
OOppss, i forgot to check it out last night.. I'll do it tonight !
Ok, for the hack now... :-)
:arrow: Switch to root user
:arrow: go to /home/httpd/html/webtools2/php/WebToolsApp
:arrow: Edit the file WebToolsApp.phb
:arrow: Search for
if (!$this->security_manager->isAccepted($user_id))
and remove the !
Then take your favorite browser (Mozilla :-) ) and go to
https://Your_OXE_IP_Address/webtools2/php/index.php
Login with user mtcl and as a password mtcl ...
Enjoy !
Frank
PS: There are some other users that you can use. Go to the Authentication folder, and you'll see a file called UserAccountsAndProfiles.xml ... There are some restricted users too (root and alcatel) , and a new user that I never used: clark
Frank.
alex
Post by alex »
frank wrote:PS: There are some other users that you can use. Go to the Authentication folder, and you'll see a file called UserAccountsAndProfiles.xml ... There are some restricted users too (root and alcatel) , and a new user that I never used: clark
Frank.
Great! Thanks.I'll check it later this week
Hi, Alex
About webtools2 - this thing exist from release 6.1?
alex
Post by alex »
vad wrote:Hi, Alex
Actually I do not know.
Anyway these features(wtools and webtools) look like unfinished projects.
May be they have been closed or frozen.
Return to “MAIN”
