Voice guides
selectt_DUP
Voice guides
Post by selectt_DUP »
Customer has recorded dynamic voice guides onto system and working fine.
Now the customer has had some professional guides recorded to replace the guides he recorded via the telephone handset.
I know the dynamic guides are in usr7/vg/dhs as i can view them.
Can i replace the voice guides with the customers recorded guides via ftp ?
If so and what format is required or do i need to you VG transfer tool ? If so what is the procedure ?
Sorry for so my questions just a little nervous touching the voice guides that are in place.
Thanks in advance.
knightr1der
Re: Voice guides
Post by knightr1der »
Not as straight forward as that unfortunately.
You really need an application called "Alcatel Audio Station" to convert the WAV file to file type needed for the OXE.
Don't be fooled by the fact you can FTP existing guides from OXE to PC and rename by adding .wav extension and listen on PC.
The conversion process by AAS creates a checksum and a couple of labels inside the file amongst other things that the OXE needs to recognise it as a valid file! :(
selectt_DUP
Re: Voice guides
I guess the "alcatel audio station" has to be purchased via Alcatel, is so how much ?
I only have 4 or 5 recordings can anyone help and convert them for me ?
Paul
oldboy
Re: Voice guides
Post by oldboy »
What release of software are you using on site????
knightr1der
Re: Voice guides
oldboy wrote:What release of software are you using on site????
does that make a difference oldboy? :?
Eliott_DUP
Re: Voice guides
Post by Eliott_DUP »
Yes. As the topic was posted in OXE / A4400 forum and he spoke about OXO... 8)
knightr1der
Re: Voice guides
Eliott wrote:Yes. As the topic was posted in OXE / A4400 forum and he spoke about OXO... 8)
And where does it say OXO ? :?
Eliott_DUP
Re: Voice guides
Here:
...a OXO with common hardware not crystal....
:mrgreen:
Okay. Was in a PM :twisted: :wink:
Re: Voice guides
hahahaha wow now we are in troubles, Elliot learned to read minds and predict mistakes :lol:
knightr1der
Re: Voice guides
cavagnaro wrote:hahahaha wow now we are in troubles, Elliot learned to read minds and predict mistakes :lol:
Ah yes, that will explain why this happened;
Return to “System”
