site photography
Alcatel Configuration Tool for International Sales -all ACTIS related topics, how-to's, tips and tricks.
selectt_DUP
site photography
Post by selectt_DUP »
The ACTIS tool comes with a site photography tool allowing you to extract the system configuration for import into the ACTIS program.
I can log into 4400 and oxe's no problem using a analogue modem but when i login and use the site photography tool the system looks as though it is downloading files but allways comes up as "download failed".
Any help ?
Also what directory would i need to access if i was to extract the files manually ?
knightr1der
Re: site photography
Post by knightr1der »
not sure about CRAPTIS :lol: but file locations etc.. as follows;
1. Log in to swinst and perform a backup of OPS. This will save the correct board positions and relevant files to the right location.
2. Then log in via mtcl and change directory to /usr4/BACKUP/OPS and ftp all files from there to your PC. If dialled in via modem then enter command;
(1)xa000001> gkermit -i -s *.*
A prompt will then appear and tell you to switch on your local kermit to receive the files. Procomm will sense this and automatically start receiving the files.
You only need the xxxx.zip in "Craptis".
Regards.
Return to “Actis”
