e&m
stekmtiki
e&m
Post by stekmtiki »
hi
in alcatel documentation there is no talk about type V e&m connection. i have a customer who is using a frad equipment(motorola vanguard 6430) and it is configured to use type V e&m with wink start.
any one faced same problem?
please see the configuration of frad:-
Port Number: 7/
Node: BOL-LAGO Address: 800 Date: 7-FEB-2036 Time: 23:05:13
Port Record Examination: Port 7 Page: 1 of 3
[7] *Port Type: VOICE
[7] Interface Type: E&M
[7] *Signaling Type: V
[7] E Lead Filter: Disabled
[7] Signaling Mode: Normal
[7] Signaling Control: Wink
[7] Compression Rate (KHz): 8GkB
[7] VAD Control: Enabled
[7] H.323 Dynamic Coder: Enabled
[7] Smoothing Delay (msec): 150
[7] Echo Canceller: Enabled
[7] Echo Return Loss (dB): -6
[7] Input Signal Level (dB): 3
[7] Output Signal Level (dB): 3
[7] FAX Support: Enabled
[7] FAX Rate (KHz): 9.6k
[7] Use Local Subscriber Address: Enabled
[7] Group Subaddress (Hunt Group): 853
Press any key to continue ( ESC to exit ) ...
Node: BOL-LAGO Address: 800 Date: 7-FEB-2036 Time: 23:05:30
Port Record Examination: Port 7 Page: 2 of 3
[7] No Answer Timeout (sec): 0
[7] Variable Digits Timeout (sec): 0
[7] Billing: OFF
[7] Local Subscriber Address: (blank)
[7] Enhance Debugging: VSM_STATS
[7] Rx Signaling State Change Filter (msec): 10
[7] Rx Disconnect Timer (msec): 1500
[7] Rx Minimum Flash Hook Time (msec): 300
[7] Rx Maximum Flash Hook Time (msec): 1000
[7] Re-configure DTMF/Pulse Digits and Wink/Delay Timer Parameters?: Yes
[7] Rx Wink/Delay/Seizure-Ack Timer (msec): 1000
[7] Rx Minimum Receive Wink/Delay (msec): 100
[7] Rx Called End Glare Detect (msec): 4000
[7] Rx First Digit Timer (sec): 10
[7] Rx Interdigit Timer (sec): 15
[7] Tx Wink/Delay/Seizure-Ack Delay (msec): 50
[7] Tx Wink/Delay Width (msec): 250
[7] Tx Digit Delay (msec): 2000
Node: BOL-LAGO Address: 800 Date: 7-FEB-2036 Time: 23:06:10
Port Record Examination: Port 7 Page: 3 of 3
[7] Tx Digit On (msec): 300
[7] Tx Interdigit Time (msec): 100
[7] Tx Interdigit Pause Time (msec): 500
[7] Tx DTMF Digits Amplitude: -7
[7] Re-configure Call Progress Tone Parameters?: No
[7] Packet Delay Measurement Period (msec): 0
cheers!
Return to “GENERAL”
