4635 French installed need English cues
bouncer_ie
Post by bouncer_ie »
Hi All,
Had a look through the tech docs and came up blank on this. As part of the upgrade kit the 4635 came with HDD on board the VPU6 with software. However the only language is European French and since I am in Ireland so I need English. How do I upload a new language to replace this?
Thanks much
B
alex
Re: 4635 French installed need English cues
Post by alex »
Sure. you need CDs with SW distribition of your VM version.
They include all languages released.
On BPWS there are some 5.x.x releases available.
bouncer_ie
Once I get the CDs what is the method to upload the new languages?
alex
Post by alex »
First you'd better check TC0226 - it is a must.
On both CDs there is /doc directory (they are duplicated). File install.pdf contains very useful info on install an upgrade.
bouncer_ie
I did are search for the TC0226 on the technical Kbase but came up a blank tried several variations etc. If you have a copy can you upload to pastebin? Also I had a look at the docs on the CD which seem really old all UNix stuff,and refer to a BOOTPD application which I cannot find anywhere on the BPWS. Is this still available?
Appreciate the help
B
alex
Post by alex »
bouncer_ie wrote: .. BOOTPD application which I cannot find anywhere on the BPWS. Is this still available?
B
BOOTPD used is the same which is used for loading of UNIX releases of 4400 SW (up to 5.0), e.g. /d2314/pcmao/boot_res/bootnt95/ directory.
Return to “Voicemail (46x5)”
