SMDR and CSTA Information Request
howyadoin
Post by howyadoin »
I would appreciate any comments as to which is the best mechanism for extracting ticket data from a 4400 system.
Also any advice on how to setup either or both CSTA or SMDR
HYD
laroth
Re: SMDR and CSTA Information Request
Post by laroth »
Under - system - V24 ports- (port number) you can configure the serial ports on the cbrma box.
under Terminal Type - choose either VT100 or Printer
under Application - choose the appropriate one.
But you must have the correct license to obtain tickets
The Alcatel 4400 has in integrated Call charging module “integrated metering” also.
It’s possible to use IP instead of a serial port if you have the license for it.
howyadoin wrote:I would appreciate any comments as to which is the best mechanism for extracting ticket data from a 4400 system.
HYD
My best advice...read damn documentation and search N posts on this forum about it...
