OXE - R.6.1.1 Not showing IP Touch 4008
sera544
Post by sera544 »
Dear All,
In OXE - R.6.1.1
Static Patch - F2.502.5...I am trying to create the IPTouch 4008 users...IP Touch 4008 It's not even in the set type...Any idea's...
Note : I get IP Touch 4018 & 4028
Thanks in Advance..
cheers,
ACSE Business R.9.x
knightr1der
Re: OXE - R.6.1.1 Not showing IP Touch 4008
Post by knightr1der »
If I remember - 4008 is a new member of the IPtouch family and was only introduced in Release 7 onwards
torrentula
Post by torrentula »
Knight hit the nail on the head...you need to upgrade for 4008 to work.
sera544
Post by sera544 »
torrentula wrote:Knight hit the nail on the head
Hi torrent...i got a nail now....thanks for that...but cau u guyz pls confirm...system has to be upgraded to R.7 or even 6.2 is fine...
cheers,
ACSE Business R.9.x
Yes I had same problem at one customer...
tincho.rn
Post by tincho.rn »
You wont be able to upgrade to 6.2. You will have to upgrade to at least 7.0
Regards.
torrentula
You can upgrade to what ever release you want, but you have to pay for the R8.0 license.
and also SMS....if you didn't pay like 3 years, then on this new one you will have to pay those 3 years as well. As any other company by the way...
Return to “System”
