I will be setting up the DNS server of our office. We will have the "yourdomain.com" redirected to the ECS. We will be hosting everything except for our webpage which will still be hosted externally.
How can I forward any DNS requests to an external IP address? I cant seem to find it anywhere.
DNS forwading
- frank
Re: DNS forwading
I just received an OXO + ECS.
Will try to play with it next week, and help.
F.
F.
- tot3nkopf
Re: DNS forwading
frank wrote:I just received an OXO + ECS.
F.
I've got ECS on VmWare
- frank
Re: DNS forwading
Ok, I tried to install it on VmWare with no luck.
What kind of plateform did you chose ?
Anytime I installed it, and restarted vmWare, it reacted like nothing was installed, and went through the whole process again ..
- tot3nkopf
Re: DNS forwading
Didn't install it myself, but I know that you have to choose at HDD type skazi and then change it to IDE (after installation). Moreover you need to edit manually the .ini file and do same thing. If you want maybe I can put this machine on an FTP server.
Regards.
Regards.
