VG Board
Re: VG Board
You need an Audio Station PC, which has a PCMCIA card reader/writer to do the job.
rovello.razon
Re: VG Board
You can use your Alcatel audio station but make sure your PC has a slot for the flash card. Edit the guides first like in new CPU but transfer that edited guide in the flash card
Eliott_DUP
Re: VG Board
And you need a special driver. Correct me, if I'm wrong.
GPA1 with RAM card and/or GPA2 with flash memory can be handeled better.
Maybe an option to add a GPA2?
Re: VG Board
No driver...we installed a new pc moved the Flash card reader and worked fine with all PCMCIA cards we had.
Eliott_DUP
Re: VG Board
Okay. Then it was in Win95 only - maybe.cavagnaro wrote:No driver...we installed a new pc moved the Flash card reader and worked fine with all PCMCIA cards we had.
Re: VG Board
Yeah that was the same that old people told me...but on XP worked fine...
Re: VG Board
knightr1der
Re: VG Board
Don't worry Eliott - I too used to think Cav was a man... at least until I met him in real life... his diaper/nappy only came off last yearEliott wrote:cavagnaro wrote:old people
