is there a way to use a DECT (analog device) or AlcatelDECT (MIPT300 e.g) together with 4059IP. The secretary isn't always on her desk.
Right now I configured MODE1 to the analog DECT. But how to do a transfer.
What is the standard solution?
Nowi
4059IP plus DECT
torrentula
Re: 4059IP plus DECT
I don't think it's possible with 4059. I have always used a regular extension and put the DECT in tandem with it in situations like yours.
Eliott_DUP
>AlcatelDECT (MIPT300)
No.
But MIPT is Wireless LAN and not DECT
And analog is also not real DECT. (One phone with a single base connected to an Z port is no DECT)
It's possible with IPtouch 8/9 series only.
See A4059 Installation Technical Communication.
No.
- tot3nkopf
Make the distribution in attendant group in such a way that when the attendant is withdrawn it will hit a your "DECT".
Also manage the entity to have the second distribution rule as your "DECT" (for overflow and external calls).
However your attendant needs to "sign out".
Note that in this config you have no waiting guide. However a more enhanced config will be: second choice in entity "DECT" and third an incoming greeting guide (same guide as attendant waiting) with distribution to entity call pointing to your entity.
Regards.
Regards.
