Newdays Alcatel launch new product in my contry (indonesia) for small and medium bussiness, that's name OXO Lite.
I confuse about this product, what different from OXO? they said it's no different from OXO, so why they launch and my the price more cheap from OXO. Any explanation?
thankks and regards
OXO and OXO Lite
- tot3nkopf
Re: OXO and OXO Lite
Don't know we do not have OXO "lite" in Romania.
Does anybody here have " OXO lite" on their market?
- Krusty65
Only thing that I have seen that may fit the bill is the cut down OxO which had the CPU slot and one other for a mix card, it had an external power pack and was wall mountable.
And it was called........(goes searching round the office for the one that I know is here).......
which then had no name on it
but I think that is was called the OmniPCX Compact
K.
K.
adverts89_DUP
We have the OXO Compact here in Australia. Its effectivly a 2 slot OXO (1 for CPU 1 for Card)
You can also use a "minimix" daughterboard on the cpu which can provide 2 basic rate ports and 1 SLI port.
Makes the OXO a little more competitive in the smaller markets.
- tot3nkopf
ipunk_oks
Sorry, i think oxo lite n OmniPCX Compact is different, cause oxo lite used 1u,2u or even 3u chassis, it's just same with oxo but cheaper
- tot3nkopf
ipunk_oks wrote:Sorry, i think oxo lite n OmniPCX Compact is different, cause oxo lite used 1u,2u or even 3u chassis, it's just same with oxo but cheaper
If so they are not the same. we don't have this for our market.
agung4u_DUP
oxo lite is oxo with very limited lisence, it use for 32 and 48 user (analog and digital) with trunk line 8. it more cheap then oxo because the lisence only for that user and trunk, if we add more user, must upgrade with oxo (same we buy new oxo).
any correction?
rgds
any correction?
rgds
