x25visu
config
x25visu
Post by config »
The command x25visu
tireur id=0 utilise (adr :223a5b70)
type 4 =>APPLI , adr 0-0-0, node 0
type_acces 0, actif 1, pt_point 223a5b18
tireur id=1 utilise (adr :223a5bb8)
type 8 =>Hybr_B, adr 19-0-0, node 1
type_acces 2, actif 1, pt_point 0 Link 2000, deborde_it 1, acces 1
TS Q0 >=< max 0-0-0
TS Q1 >=< max 0-0-0
tireur id=2 utilise (adr :223a5ba0)
type 8 =>Hybr_B, adr 19-0-1, node 1
type_acces 2, actif 1, pt_point 0 Link 2000, deborde_it 1, acces 2
TS Q0 >=< max 0-0-0
TS Q1 >=< max 0-0-0
tireur id=3 utilise (adr :223a5bd0)
type 6 =>V120dte , adr 0-17-30, node 0
type_acces 0, actif 1, pt_point 223a5e68
tireur id=4 utilise (adr :223a5be8)
type 6 =>V120dte , adr 0-17-31, node 0
type_acces 0, actif 1, pt_point 223a5ec0
tireur id=510 utilise (adr :223a5b88)
type 17 =>SPYDER_FR , adr 0-0-0, node 0
type_acces 0, actif 1, pt_point 223a5f18
that means adr 0-0-0 from a fragment:
tireur id=0 utilise (adr:223a5b70)
type 4 => APPLI, adr 0-0-0, node 0
in shelf 0 board 0 costs intof on too place registered board eUA32 and looked x25visu, too most deduces
knightr1der
Re: x25visu
Post by knightr1der »
uh? :?
Re: x25visu
In english??
When I launch x25visu I get:
[0]: Exit [1]:cluster [2]:cluster+points [3]: points [4]: phys_clust [6] tabeqt_free
with option 1 I see what you post but how to translate that?
What are the other options?
knightr1der
Re: x25visu
config
Re: x25visu
Post by config »
Has understood that it means
Re: x25visu
I'm sorry? I personally don't understand your english...sorry...can you please be more specific?
Gedeon
Re: x25visu
Post by Gedeon »
tireur_id : It's the X25 Access Group (in french, Groupe d'accès X25) .
The GA0 is dedicated to X25 applications used by ABC network.
In GA0, you can find many Access Point, like 134 (IP/X25 Tunnel) 108 (Broadcast), etc...
The adr 0-0-0 is not the position of a coupler in this case.
The information actif =1 indicate that this access group is operational, it's a good thing for your network.
pt_point is a memory address in the x25 remanents.
The x25 commands are not very easy to use, and the documentation is very light in the cd-rom.
G.
knightr1der
Re: x25visu
ZzZZzzzzZZzzz
ben92
Re: x25visu
Post by ben92 »
most of the time, adr 0-0-0 in x25visu means that is not a physical address (not used)
config
Re: x25visu
Post by config »
by testing has found out that adress 0-0-0 is used for sosm 0
Return to “X25”
